Scored a HDPE cutting board, how do I...
Forum topic by InstantSiv posted 07-31-2015 11:01 AM 1171 views 0 times favorited 9 replies Add to Favorites Watch
View InstantSiv's profile
InstantSiv
262 posts in 1828 days
07-31-2015 11:01 AM
I scored a 48” x 12” to 18” x 1/2” HDPE cutting board from a restaurant. The surface is looking pretty rough so I want to clean it up but I don’t have a planer or jointer.
Would sanding it work? If not are there any other ways to resurface it?
Other than cutting boards and miter slot bars what can hdpe be used for?
9 replies so far
View mahdee's profile
mahdee
4040 posts in 2001 days
#1 posted 07-31-2015 11:03 AM
Hand plane or router comes to mind. Sandpaper will get clogged up.
-- earthartandfoods.com
View SirIrb's profile
SirIrb
1239 posts in 1464 days
#2 posted 07-31-2015 11:06 AM
Sanding plastic is not usually a good idea. This type of plastic will gum up and melt more than smooth. I would suggest using a router. Also, if you do find a planer to run it through, please dont. I honestly get a bad feel from doing that. Its more a gut thing than a “yeah, i tried it and broke the planer” thing.
Are both sides of the cutting board in rough shape? The very best finish you can put on there would be using a mill with a fly cutter. Rather than the normal tool steel being sharpened to a point, use what is called a radius cutter. This will finish the plastic much better. Test run it so your RPMs are just right…if you can get to a Bridgeport, that is.
InstantSiv
#3 posted 07-31-2015 11:06 AM
Oh yeah! The router planing jig method thing. I’ve always wanted to do that. Thanks. If there’s not an easier way I probably going to do that.
InstantSiv
#4 posted 07-31-2015 11:16 AM
<blockqoute>
From what I’ve read people have run hdpe through planers with no issues. The only thing they’ve mentioned is cleanup is a pain. Other types of plastics could be an issue but hdpe is okay.
View rick1955's profile
rick1955
264 posts in 1664 days
#5 posted 07-31-2015 02:21 PM
A planer is fine. When I worked for a tool dealer a couple of guys were setting up a business to resurface commercial cutting boards. We ran a bunch of test samples and it worked great. I’ve also planed trex successfully.
-- Working smarter with less tools is a true crafts person...
View Yonak's profile
Yonak
986 posts in 1754 days
#6 posted 07-31-2015 07:22 PM
Two ideas that came to mind to me are trying a card scraper and, if it’s only dirty and not a rough surface, put it in the dishwasher.
View TheFridge's profile
TheFridge
10814 posts in 1719 days
#7 posted 07-31-2015 07:25 PM
I’ve used saws planes jointers and planers on uhmw without a problem.
I card scrapers would prob work well.
View JeffP's profile
JeffP
573 posts in 1625 days
#8 posted 08-01-2015 02:25 AM
Makes for an awesome sacrificial fence if you have Saw Stop saw with an aluminum (like Incra) fence system.
-- Last week I finally got my $*i# together. Unfortunately, it was in my shop, so I will probably never find it again.
View marc_rosen's profile
marc_rosen
146 posts in 3414 days
#9 posted 08-01-2015 02:43 AM
“Other than cutting boards and miter slot bars what can hdpe be used for?”
As shielding for thermal neutrons from a nuclear reactor?
Marc
-- Windsurfing, Woodworking, Weaving, and Woodducks. "Most woodworkers are usually boring holes"
