Brad Point Bits
Forum topic by Dchip posted 35 days ago 265 views 0 times favorited 5 replies Add to Favorites Watch
View Dchip's profile
Dchip
39 posts in 149 days
35 days ago
Topic tags/keywords: question drill press
What are the disadvantages/limitations of brad-point drill bit?. I have only seen benefits, but there must be some drawbacks or else twist point bits would be obsolete, right?
-- Dan Chiappetta, NYC, http://www.9x7woodworks.com
View SwedishIron's profile
SwedishIron
81 posts in 537 days
35 days ago
The only cons I can think of are:
1. The greater expense upfront to purchase quality HSS brad-point bits
2. They are a bit more work to sharpen.. but I heard from a fellow woodworker that a higher end BitDoctor tool can sharpen them.. I haven’t verified that yet..
As for the pros: 1. No tear out… entering or exiting..
-- Scott, Colorado
View dbhost's profile
dbhost
620 posts in 128 days
35 days ago
Higher cost of production due to more difficulty in sharpening.
Brad point bits are also not particularly strong when cutting very hard materials like Steel.
For woodworking applications, they rock. I have a set on my wish list, for metal working, I wouldn’t use them.
The advantages of course, no skating, no tear out etc… make them well worth the investment.
-- Trying to follow the example of the master.
View ondablade's profile
ondablade
68 posts in 95 days
35 days ago
Another question in the same vein. I’ve just coughed up a fair amount of money (over $200 equivalent) to Dieter Schmid Fine Tools in Germany for a set of Famag HSS-G brad point bits from 1mm to 16mm – on the basis that i wanted to be able to drill consistently clean holes without problems and wasn’t wild about the performance of cheaper hardware store types I’d bought locally.
They’ve just arrived and i’ve not tried them yet, but they look and feel absolutely beautiful, are very precisely ground and seem razor sharp.
But i can’t help wondering what if anything paying this much buys when i see some of the big US tool houses offering something nominally similar at a fraction of the price. (trouble is they are in imperial sizes which is a bit of an issue for me too)
Similar questions arise in buying Forstner bits – a set of 15 metric Famag Bormaxes rated for use in hardwood comes in at around $350 – but again you see ‘HSS’ Forstner’s for sale for a fraction of that.
On the other hand my current set of cheap Forstners is a pain – many wouldn’t even drill without considerable reworking as the angles were ground all wrong, and even then they seemed to be made of cheese…
I’ve not worked up the courage to plump for the Forstners yet, but i’m very tempted by the idea (if it’s true) of buying good stuff once as i hate junk tools :-)
Thoughts???
ian
-- Late awakener....
View JMK's profile
JMK
6 posts in 35 days
30 days ago
The biggest advantage I have found for twist drills is if you need to resize a hole. Brad point and forster bits won’t find center but twist drill bits will.
JMK
-- JMK
View SEE's profile
SEE
62 posts in 64 days
29 days ago
I think that both brad points and twist drills have their place. I don’t see it as an either/or situation.
-- Build for the joy of it!
