Riving knife with cross cut sled?
Forum topic by CTW posted 07-30-2015 10:38 PM 1457 views 0 times favorited 15 replies Add to Favorites Watch
View CTW's profile
CTW
48 posts in 1273 days
07-30-2015 10:38 PM
Topic tags/keywords: jig question tablesaw
My only acess to teachers are online (like many other beginners). I am in the process of completing my first successful ♡ (I hope) crosscut sled. I have never seen or heard of anybody using their riving knife with a sled but when Mr. Ng mentioned potential kick-back while using a sled in his vdeo I started wondering whether it should be used.
I would really like some input from someone who has a good understanding of this issue.
Thanks, CTW
15 replies so far
MrUnix
6580 posts in 2162 days
#1 posted 07-30-2015 10:47 PM
Completely unnecessary with a sled (or when using a miter guage for that matter). Doesn’t mean you can’t still use it though if you feel the need.
runswithscissors
2724 posts in 1988 days
#2 posted 07-31-2015 12:01 AM
The rk might help prevent the offcut from drifting into the back of the blade.
View DKV's profile
DKV
3940 posts in 2467 days
#3 posted 07-31-2015 12:57 AM
runs, help me with the physics behind your statement.
-- This is a Troll Free zone.
View Redoak49's profile
Redoak49
3191 posts in 1951 days
#4 posted 07-31-2015 01:10 AM
I leave the riving knife in all the time . The only time I take it out is when cutting a groove as mine is a little higher than the blade.
View Steve Peterson's profile
Steve Peterson
370 posts in 3045 days
#5 posted 07-31-2015 01:22 AM
Redoak49, it sounds like you have a splitter instead of a true riving knife. Either that or something isn’t adjusted properly. A true riving knife should travel with the blade and would always be slightly lower.
-- Steve
View Woodmaster1's profile
Woodmaster1
918 posts in 2550 days
#6 posted 07-31-2015 01:30 AM
I leave mine on because I am too lazy to take it off. The sled works just fine without removing the knife.
View Gixxerjoe04's profile
Gixxerjoe04
850 posts in 1539 days
#7 posted 07-31-2015 03:12 AM
If my saw had a riving knife I would keep it on, I have crosscut some pieces of lumber that had tension pulling it back into the blade, but that happened before all the way through and I pulled it back out thankfully.
View CTW's profile
CTW
#8 posted 07-31-2015 04:02 AM
Thanks for the input. I know the riving knife is supposed to keep the wood behind the blade from squeezing together and climbing the blade and kicking back, but for some reason I didn’t think cross cutting. presented that risk. But I don’t know why.
MrUnix
#9 posted 07-31-2015 04:11 AM
Check out Matthias trying to get a kickback:
Table saw kickback from crosscuts - an experiment
View CTW's profile
CTW
#10 posted 07-31-2015 04:25 AM
Thank you. I will do that.
View Tomoose's profile
Tomoose
422 posts in 3336 days
#11 posted 07-31-2015 04:35 AM
My riving knife doesn’t interfere with my sled at all, so I just leave it on. I have not encountered an instance where I would need to remove it, but that is not to say that situation is not a possibility.
Tom
-- “I am always doing that which I cannot do, in order that I may learn how to do it.” Pablo Picasso
View rwe2156's profile
rwe2156
2881 posts in 1443 days
#12 posted 07-31-2015 11:21 AM
If you have a riving knife why would you even take it off when using a sled?
Am I missing something?
Redoak49
#13 posted 07-31-2015 11:27 AM
Steve….I have a Sawstop PCS and yes it is a true riving knife. Some of my blades have been sharpened a couple of times and yes the RIVING knife is slightly higher than the blade on some of them.
View CTW's profile
CTW
#14 posted 07-31-2015 05:45 PM
Red, I also have the Sawstop pcs – so if (when) I have questions about it I may be asking you.
View patcollins's profile
patcollins
1683 posts in 2828 days
#15 posted 08-05-2015 12:45 AM
The wood pinches while ripping the length of the grain because of internal stresses are released from cutting out a section of the wood. It may want to twist, both sides of the cut may want to come together or even spread apart.
These stresses don’t exist across the grain, nor do they exist in homogeneous material like MDF, particle board, or plastic.
