Mortising jig on a drill press or dedicated mortising machine?
Forum topic by scott_v posted 31 days ago 344 views 0 times favorited 7 replies Add to Favorites Watch
View scott_v's profile
scott_v
5 posts in 32 days
31 days ago
I plan to build Shaker and Mission style cabinets and furniture. Should I invest in a dedicated mortising machine, or can I get away with using a mortising jig on a drill press? I have limited shop space and am hoping I can make quality mortises using the DP. Also I’d appreciate some brand/model recommendations.
Thanks!
Scott Vroom
View TheDane's profile
TheDane
195 posts in 556 days
31 days ago
I would go for a dedicated hollow-chiself mortiser.
I confronted the same issues a few years ago when I decided to build a Morris Chair, coffee and end tables, and TV cabinet. I talked to some of the guys who gather for woodworking seminars on winter mornings at a local machine shop, did a lot of reading, and came to the conclusion a dedicated mortiser would be a better way to go.
The problem most guys had with the drill press attachments is they kept coming loose, which makes neat, repeatable mortises a little tough to get. It is also hard to get enough leverage with most attachments to plunge into hardwoods.
I wound up with a Jet JBM5 (bought it on sale at Menards 3+ years ago for under $200). I outfitted it with a wider table (from Rockler), and mounted it on a plywood base with a cleat across the front so I can keep it stabilized on my bench with only one clamp.
The Jet is not perfect, but it compares favorably with machines from Delta, ShopFox, etc. with one notable exception: the fence can be a pain to set. The fence is attached to a steel hex rod that is held in place by a thumb screw. There is no rack & pinion fence adjustment (like the one on Delta’s mortiser), so getting the workpiece centered on the table is more trial & error than I am comfortable with.
I have figured out how to install and align the chisels to get the results I want.
-- The only place success comes before work is in the dictionary. -- Vincent T. Lombardi
16636 posts in 470 days
31 days ago
Hey Scott
No contest a dedicated hollow-chiself mortiser is quick and easy the only thing I like better is my Multi Router.
View papadan's profile
papadan
445 posts in 261 days
31 days ago
I have a Delta Mortising attachment that didn’t work worth a darn on my old benchtop Ryobi drill press. After getting my Delta full size drill press it works very well.
-- Dan-- Info for all @ http://www.hoistman.com
View CessnaPilotBarry's profile
CessnaPilotBarry
1263 posts in 595 days
31 days ago
I’ve tried a few drill press mortise attachments and was not impressed at all. Drill presses are not designed to exert the proper amount of down force, have tables that are too small and high, and they’re too top heavy to be reefing on the handle.
I currently have a Powermatic stand-up mortiser. It is fantastic for repetitive mortising, as well as large mortises such as you might find on entry doors. Be advised that you need to do an awful lot of mortises to make the machine worth having. I love having mine and won’t part with it.
Before the PM, I used my plunge router and Tage Frid (the one that looks like a miter box) or shop-made base jig, or a bradpoint bit, drill press, and hand chisel. I’ve used benchtop machines in schools and prefer the plunger and jig or drill press and hand tools. The benchtop machines that I used were OK, and better than drill press attachments, but in my eyes, not better than the other methods.
If you see yourself as making lots of chairs or odd shaped furniture, a Domino might serve you well.
The cat’s ass of mortising flexibility and repeatability has to be the Multi-Router, but bring $$$! <g>
For typical hobby furniture making, a drill press, brad point bits, hand chisel, or plunge router work really well at little extra cost and time. A support block can be easily made to keep the chisel square to the face, and the slower stock removal of the hand tool allows sneaking up on a fit. Alternatively, you can fine tune the tenon to fit plunge routed mortises.
I bought my big machine to do a custom run of entry doors. If I hadn’t done that job, I’d still be happy with my previous methods. There is no way the big machine earns it’s keep at hobby volumes.
Have fun!
-- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread...
View Vincent Nocito's profile
Vincent Nocito
146 posts in 257 days
30 days ago
Dedicated mortiser is my first choice. A router and sharp chisels is my second. Drill press mortising is a far distant 3rd. If you plan on Mission furniture, you will appreciate the speed associated and accuracy with the dedicated machine.
View Peter O's profile
Peter O
1016 posts in 767 days
30 days ago
You can get by with a drill press attachment. But it’s no contest: the dedicated machine does the job better.
-- http://www.north40custom.com -- http://north40studios.etsy.com --
View Damian Penney's profile
Damian Penney
1030 posts in 884 days
30 days ago
Have you looked at the Mortise Pal? http://www.mortisepal.com/ I like mine so much that my dedicated mortiser is gathering dust.
