Mitering thin pieces on a CMS, got any tips?
Forum topic by CB_Cohick posted 07-30-2015 03:44 PM 731 views 0 times favorited 6 replies Add to Favorites Watch
View CB_Cohick's profile
CB_Cohick
484 posts in 1215 days
07-30-2015 03:44 PM
Topic tags/keywords: question maple miter saw milling
I was cutting a 45 angle on some quarter-inch thick strips of maple (face towards the fence) recently on my compound miter saw, and on several cuts the piece pretty much just exploded. I repeated the process with poplar and had no trouble. Obviously there is some property of the maple, I assume hardness, that didn’t agree with my technique. I am wondering if any of you might have a handy tip for me should I try this again. My thought was that sandwiching my piece between some sacrificial strips might help. Any idea what causes the maple to hate that process?
Thanks for your input.
-- Chris - Would work, but I'm too busy reading about woodwork.
View Daruc's profile
Daruc
460 posts in 1097 days
#1 posted 07-30-2015 05:13 PM
Put together a small L-shaped board and mount it to your saw fence.
When you make a cut, don’t cut all the way through your board.
This will give you support all the way across the fence.
View BinghamtonEd's profile
BinghamtonEd
2297 posts in 2333 days
#2 posted 07-30-2015 06:39 PM
+1 to the fence. You may also consider building a small miter box that accepts a Japanese flush cut saw for small detail work.
CB_Cohick
#3 posted 07-30-2015 06:45 PM
- BinghamtonEd
I think this is a great idea, and a much safer solution. I need to learn to think outside the “box” (pun intended ;) ) of the first tool I pick up to use and ask myself if there may be a better answer for my intended application.
View JayT's profile
JayT
5587 posts in 2175 days
#4 posted 07-30-2015 06:55 PM
There was a project post a few months ago of a really nice looking miter box for a Japanese pull saw. You might be able to use it for some inspiration. Not my project, I just thought it was very well done.
Click for details
View HokieKen's profile
HokieKen
4736 posts in 1102 days
#5 posted 07-30-2015 07:06 PM
For the CMS, in addition to the ZCI pieces, make sure you have a sharp, fine pitch blade for clean cuts.
But, that miter box^ just looks too cool not to make.
-- Kenny, SW VA, Go Hokies!!!
View AandCstyle's profile
AandCstyle
3025 posts in 2221 days
#6 posted 07-30-2015 11:30 PM
I like my scms a lot, but use a Nobex Pro MS for delicate pieces.
-- Art
