| Forum topic by thedudeabides | posted 31 days ago | 325 views | 0 times favorited | 17 replies | ![]() |
31 days ago |
Here in New England it’s already starting to reach the threshold for items being kept in my barn workshop. Woodglues and most paints and stains, but even my air compressor says in the manual it’s not a good idea to store in severe cold temps. So, outside of the obvious, what else are you guys making sure doesn’t stay exposed to freezing temps over the winter? |
31 days ago |
My shop does not often drop below freezing, however, just to be safe, I move my waterstones inside for the winter. |
31 days ago |
My shop is heated so I dont have to worry about freezing but I would be careful of anything that has a cast iron top, condensation can make them rust very quickly. -- A hammer dangling from a wall will bang and sound like work when the wind blows the right way. |
31 days ago |
I’m planning to bring everything in except for the large tools. I use an unheated garage as my shop, so I like the idea of bringing tools into a climate controlled building to reduce the chances of rust. |
31 days ago |
Just for grins, I wanted to let you know that last year my garage shop didn’t drop below ~60 degrees. One of the benefits of living in Houston TX! -- Derrek L. |
31 days ago |
Derrick, What’s the other benefit of living in Houston—-Sweating when you get out of the shower in August? LOL—-My son lived there for a while going to school. He doesn’t miss the humidity, although we could do without the wind in Lubbock. We don’t get too cold here, but we get below freezing pretty often. My shop is not heated, except for a space heater, but is well insulated. I worry about my glue more than anything. Just having in a cabinet seems to be enough most of the time. -- Kent Shepherd * The goal is-----More Tools! |
31 days ago |
I eventually got tired of moving freeze sensitive items into the house, so I put heat in. Around here you need heat from September through April if you want to be comfortable working in there anyway. I agree with cstrang that it helps keep the area dry too so the equipment doesnt rust. I usually leave the heat at about 50-55 during the winter, and turn it up to about 60 when I am working in there. -- Wayne - Plymouth MN |
31 days ago |
It’s heat that is my problem here. -- Trying to follow the example of the master. |
31 days ago |
Any and all glues and latex paint. Those of us that live up north don’t mind working in the cold, but I did put a bit of heat in the shop last winter. One benifit of working in the cold is that all those little nicks and cuts you get don’t bleed much. I think that is the only benifit. -- Dave- New Brunswick |
31 days ago |
glue, 18v batteries and water based finishing products all come inside when its cold |
31 days ago |
We don’t get snow but it does get cold now and then….but not usually below 25degrees…..most of the lows here are in the 30’s-40’s…..so it is fairly moderate. We get the heat in summer….but its a dry heat…I come from Lousianna so I am used to humidity…none here though…just 100+ temps often enough. I do have my new shop heated though…I put in a nice mini pot belly wood stove…I burn my scraps and a few “cough” blown projects now and then….keeps the place neat…and warm… -- Woodworking.....My small slice of heaven! |
31 days ago |
One of my books shows how to build a simple box It was meant to house stain and finishing products. I can probably find the plan, and scan it in … if you want. Seemed like a cool idea…. -- -- Neil |
31 days ago |
This is my first winter caring about tools… should I be concerned about my new mini lathe in an unheated shop? It gets kind of dank in there… maybe I should think about cleaning and rust issues. Yikes! -- Lisa Chan, custom cafts and yarn accessories, http://www.grippingyarn.com |
31 days ago |
I guess living in southern California and only having temps get to around 45 or so in the coldest months with nearly no humidity is spoiling me. -- San Diego, CA US Navy |
31 days ago |
I got tired of the move it out in the fall, bring it back in come spring. Put in an attic style forced air furnace. Leave it at 45 but turn up to 60 to work. -- Always remember you're unique, just like everyone else |
30 days ago |
Stains, glues, paints, and batteries all come out….probably the gold fish too! :D |
30 days ago |
Scott, Mrs. Paul’s would beg to differ with you. ;-) -- -- Neil |
30 days ago |
Typically speaking, during the coldest part of the year, we see a week or so of below freezing temps as overnight lows, typically in late January. Those sub freezing temps usually last less than an hour or so. On particularly hard winters, when we have a “hard freeze” (under 32 deg F for more than 4 hours) I will set old towels in the door gaps of the garage doors, and set an oil filled electric radiator on low. Temps in my shop never dip below about 45 deg F. Like I mentioned, honestly too shortly above, it’s not low temps that is my problem, it is high temps. Glues, stains, and paints tend to set up in their bottles rather quickly. (One of the reasons I like Titebond II and Titebond III is that they do not go bad as quick in the summer as say, Gorilla Glue or anything like that…). I guess it depends on how that barn of yours is built, how big it is, and how much it would cost, but I would think about insulating and heating that shop area if possible… -- Trying to follow the example of the master. |
| Forum | Topics |
Woodworking Skill Share
2897 |
3909 |
255 |
941 |
220 |
Woodworking Trade & Swap
616 |
Coffee Lounge
2363 |
LumberJocks.com Site Feedback
522 |
