| Forum topic by Odie04 | posted 32 days ago | 241 views | 0 times favorited | 7 replies | ![]() |
32 days ago |
Topic tags/keywords: question bandsaw ironsmith ironsmith bandsaw 9 bandsaw help My buddy is a mover and picked up this 9” Ironsmith bandsaw free from a job. He gave it to me, and it seems the motor has crapped out. I’ve searched the Internet for “Ironsmith bandsaw(tools, .com, etc.) and haven’t been able to find anything. I’m wondering if anyone knows of a parts dealer that might be able to replace the motor? -- ...Don't make fun of me. I'm brand new |
32 days ago |
Is the motor integrated or mounted to the frame? The best place is to look on the motor casing itself and then start price shopping once you know the make/model. eReplacementparts.com, Sears Outlet, M&D, eBay, etc. The challenge will be motors are expensive to replace, especially for a tool of dubious origins. Make sure the tires, elevation crank, hesitate to say guides since it probably doesn’t have them are in good shape before buying since you can purchase a comparable size Delta for between $50-$75 on Craigslist… with a working motor. |
30 days ago |
30 days ago |
Free is not always good most people don’t give away band saws. Nathan has good ideas. -- Jim from Heirloom Woodshop Southern Oregon |
30 days ago |
I would not be concerned about the metal vs wood designation. I would look for blades that may be more approprate for wood. Also, given the overall condition of the saw (appears good), have you considered taking the motor to a repair shop to see if can be repaired. Also could there be a bad switch or an electrical issue? -- We must guard our enthusiasm as we would our life - James Krenov |
30 days ago |
Have you checked out the wiring and the switch? If power is not getting to the motor, it will not run… :) :) Yes? -- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: http://www.WoodworkStuff.net ... My Small Gallery: http://www.ncwoodworker.net/pp/showgallery.php?ppuser=1389&cat=500" |
30 days ago |
Like WayneC said, I’d try taking the motor to a repair shop, if you have to replace it completly it is probably more money than its worth. But you can always try kijiji, craigslist, flea markets, etc. for a cheep replacement. Hope it works out for you, good luck. -- A hammer dangling from a wall will bang and sound like work when the wind blows the right way. |
30 days ago |
Look on the motor itself. There should be a nameplate that lists all the pertinent information (voltage, H/P, phase, amps etc.) including a manufacturer’s model# and serial#. If you confirm that the switch is OK and there isn’t an in-line fuse that is blown then I would use the info from the motor to find a replacement. P.S. GO BEARS! |
| Forum | Topics |
Woodworking Skill Share
2897 |
3912 |
255 |
941 |
221 |
Woodworking Trade & Swap
616 |
Coffee Lounge
2367 |
LumberJocks.com Site Feedback
522 |
