Looking for a router fence to clamp on to my ts fence?
Forum topic by gcwoodshop posted 07-29-2015 05:42 PM 786 views 0 times favorited 8 replies Add to Favorites Watch
View gcwoodshop's profile
gcwoodshop
5 posts in 998 days
07-29-2015 05:42 PM
Wow. What a great forum. I’ve been reading through a lot of posts. Just bought myself a grizzly g1023rlw it has the router wing attached. I did a ton of research and it seems that saw will be perfect for my needs. I have a small 16×16 shop and I am trying to set up an efficient workspace. My question is regarding a router fence. Is there a way to get a router fence( like a woodpeckers super fence) to clamp to the back side of my ts fence. I really don’t want to build one. I am open to almost any model of router fence. I called woodpeckers and they said they haven’t heard of anyone doing this. It seems like it should be simple to do. Just some kind of “L” bracket? Am I missing something? Thanks!
Travis
8 replies so far
View jerryminer's profile
jerryminer
916 posts in 1406 days
#1 posted 07-30-2015 01:51 AM
Haven’t done it, but I’m sure you could attach a couple of pieces of aluminum angle to the superfence and clamp it to your saw fence. The travel of the fence though will only be as precise as the travel of your saw fence. A Router table fence is usually more precise and sensitive than a table saw fence, IME.
View MrUnix's profile
MrUnix
6587 posts in 2164 days
#2 posted 07-30-2015 01:59 AM
Why don’t you just use your existing fence with some sacrificial boards clamped to it? Works well and all you need to do is cut a half-circle (or whatever shape you want really) in the bottom of the boards so you can embedded your router bit into it.
gcwoodshop
5 posts in 998 days
#3 posted 07-30-2015 03:06 AM
I could do that brad but I was looking for something a little more permanent and quick to set up. I was looking at my incra router fence tonight. It looks like it will easily clamp to my ts fence. I have to take it off the ls positioner of course. I wonder if I can come up with a set up that will let the positioner slide into the miter slots on my ts. Then I could use it as it was designed. I really only have room for one router table. My plan was to sell the incra and buy a different fence. I don’t use the incra often but it would be nice to keep if possible. Thanks for the replies!
Travis
gcwoodshop
5 posts in 998 days
#4 posted 07-30-2015 03:11 AM
I think I found something that will work on the woodpeckers website. I will give it a go and post a pic. Thanks for the replies. I have gotten so much good info on these forums its incredible!
Travis
View boatz's profile
boatz
92 posts in 1616 days
#5 posted 07-30-2015 12:37 PM
Check out Very Cool Suoer Tools. He has a table saw fence made from aluminum extrusions. This might work.
-- You can't always get what you want. But if you try sometimes you just might find, you'll get what you need
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1141 days
#6 posted 07-30-2015 12:55 PM
I would look into mounting the entire Incra router table system somehow to your table saw. IMHO the Incra system is the most accurate and flexible systems there is. I even replaced the Delta UniFence on my table saw with an Incra LS-TS fence.
Pay attention to feed direction with the router. You will want to feed right to left so that the router bit pulls the wood against the fence. Depending on where you mount the fence you may have to feed the wood through the router from the back of the saw. This would affect any plans to add an outfeed table to the saw.
gcwoodshop
5 posts in 998 days
#7 posted 08-02-2015 03:35 AM
I would like the incra system on my ts. My only concern is the amount of room it takes up. Especially with the router table on the right side. My shop is only 16×16 so space is very limited.
View UpstateNYdude's profile
UpstateNYdude
914 posts in 1948 days
#8 posted 08-02-2015 03:41 AM
if you get the VSC fence (which I highly recommend, it’s awesome) you could mount the Incra wonderfence right to the back side of it and use it that way, or if it doesn’t fit you could always build your own as suggested. The VSC fence is an upgrade for any saw as it should be for the price.
http://vsctools.com/
-- Nick, “I am always doing what I cannot do yet, in order to learn how to do it.” – Vincent Van Gogh
