How to cut hard maple
Forum topic by woodman71 posted 32 days ago 400 views 0 times favorited 13 replies Add to Favorites Watch
View woodman71's profile
woodman71
59 posts in 217 days
32 days ago
How to cut hard maple with out burning I just bought some hard maple to build a table it has bevel edges and the plans call for you to use table saw with blade at ten degree my blade is forrest woodworker two the table saw has three horse motor what I’m worried about is burning when making the bevel cuts the blade is not new but I think it is still sharp enough to cut but if not what blades that are not that costly that would work and how many teeth should i get is it the finer blade better chance of burning I think if I got freud with as many teeth as the woodworker two it will be fine looking for some help thanks the maple will be 1 1/2 thick and 1 3/4 think
woodman71
32 days ago
I just found this on forrest website http://www.woodcraft.com/Family/2020363/Forrest-Woodworker-II-10%E2%80%B3-40T-1-Grind.aspx look at blade teeth chart
View Mauritius's profile
Mauritius
95 posts in 119 days
32 days ago
I burnt maple on my saw with a Forrest WWII when ripping. I switched to a 24 tooth thin kerf rip blade from Freud (bought it at Home Depot for about 1/4 of the cost of the WWII) and it works great, no burns and a clean cut. You definitely want something with a lower tooth count to avoid burns when ripping.
View MedicKen's profile
MedicKen
457 posts in 355 days
32 days ago
Maple is notorious for burning. I would just be sure that your blade is sharp and use a good quailty rip blade for the cuts. Feed rate is also just as important, too slow and you will have burning as well. You may also want to check that the blade is parallel to the miter slot and the fence is parallel as well.
View Rabbet's profile
Rabbet
23 posts in 34 days
32 days ago
Their is a company called Final Cut that makes a saw blade with sandpaper attached to both sides. They claim perfectly smooth cuts. I believe they are a direct company. I’m sure they have a web site.
-Rabbet
View JasonWagner's profile
JasonWagner
88 posts in 73 days
32 days ago
You didn’t even try it yet? Try the blade you have on some scrap or 1/16” off of where you want the cut to see if it does burn. Make sure your blade and fence are parallel. Or get your Forrest sharpened if you really have an issue.
View russv's profile
russv
48 posts in 62 days
32 days ago
I also use a 24 tooth thin kerf Freud blade with good success to help prevent burning. hang your tongue out to the left and bite down lightly helps.
russv
-- yknotwood.com: where to go because you don't want no stinking plastic!
teenagewoodworker
2480 posts in 661 days
32 days ago
youll be fine with your woodworker 2… sneak up on it… if you try to cut it right to final size right off you will get burns… i agree that switching to a 24 tooth is a good ides…. i have a freud 24 tooth its the industrial that costs 60 dollars and works beautifully. just cut the bevel a 1/16 inch oversize and then do a final pass… move a little fast which should be no problem as youre only taking off a little bit of material and you should be good.
View John Ormsby's profile
John Ormsby
503 posts in 630 days
32 days ago
I use a 12” diameter 14 tooth ripping blade for cutting rock maple. I get no burning. The more teeth the more chance of burning. The friction builds up fast. Proper fed rate is also a must.
-- Oldworld, Fair Oaks, Ca
16684 posts in 470 days
32 days ago
No big deal you don’t need a $ 100 blade to cut maple just a sharp blade. I’ve used blades that cost $30.00
and they cut many different hard woods
View knotscott's profile
knotscott
521 posts in 268 days
32 days ago
The WWII may be a bit prone to burning hard maple of that thickness because it has a low side clearance and polishes the edges…same is true of the Ridge Carbide TS2000, Freud Fusion, Freud LM74 GLR, and Infinity Super General. A good 24T ripper shouldn’t burn, but might leave too rough of a cut…can always hit it with a hand plane, scraper, or sandpaper. A 30T ATB blade like the DeWalt DW7653 or the 30T WWII might be just the ticket.
Either way, a clean sharp blade will help a lot. Making a very light final pass will reduce the chances of burning. Keep the blade height on the high side, wax your table to reduce friction, make sure the alignment is good, and flatten/straighten the boards before your final cut.
russv
48 posts in 62 days
31 days ago
yeh, all of the above is good advice. And don’t forget the tongue position I mentioned earlier.
russv
View Don Newton's profile
Don Newton
528 posts in 511 days
31 days ago
Perhaps you could cut the material square and a slight bit oversized, then bevel on the jointer. That way the quality of the cut really wouldn’t matter.
-- Don, Pittsburgh
woodman71
31 days ago
Thanks everyone for the advise Russv that tongue tick is not allow my wife said if my tongue got cut off she leave me thought that sound good I cant afford a divorce right now lol
