Freud's SD208 vs SD508 Stacked Dado Set
Forum topic by ChunkyC posted 33 days ago 330 views 0 times favorited 8 replies Add to Favorites Watch
View ChunkyC's profile
ChunkyC
273 posts in 148 days
33 days ago
Topic tags/keywords: tablesaw dado set blade
I’m in dire need of a new stacked dado set. I’ve read good reviews about both but the SD508, “Super Dado Set”, runs about 2x that of of the SD208, “Professional Dado Set”, on Amazon. Is the SD508 really worth the extra money?
SD508
SD208
Thanks,
-- Chunk
View knotscott's profile
knotscott
525 posts in 269 days
32 days ago
That’s a subjective call that only you can make. The 508 has twice the teeth and definitely gives a cleaner cut…the teeth should also stay sharp longer because they share the work load.
I had the SD208 for a few years and thought it was pretty good, but think that the DeWalt/Delta 7670, Systimatic S42Fine, and Infinity Dadonator leave a cleaner cut too…the Dadonator is incredible and runs ~ $200, the Systimatic is ~ $300, and the 7670 is on sale from Grizzly for $90 shipped)...highly recommended as the most bang for the buck in that price range…nice carrying case, and nice shim stock too!
View Cato's profile
Cato
138 posts in 206 days
32 days ago
Chunky, I don’t have a dado set yet, but have kinda been looking and following Knotscotts info on them to decide what fits best for what I do in the shop.
I did notice that my local Lowe’s had the SD208 on clearance recently for $75, so you might check that out if it is a fit for you.
Rick Dennington
318 posts in 88 days
32 days ago
Hey Chunk:
I bought the Freud SD208 set at my local Lowes a couple of days ago. I cut a few dados and rabbits in a project with it—— works great. I got the last set they had, cause they are clearing them off the shelf. I got it for $69 bucks. I already had two sets, but got these for a back-up just on account.
The way I see if from where I stand, most dados and rabbits AREN”T going to be seen anyway, so it’s no big thing to worry about. As long as they cut a clean bottom and the part fits, that’s all you need. You have plenty of blades and shims to “get’er done”. Just my theory.
-- Remember--- one good turn-- gets most of the blanket!!!!
View Timbo's profile
Timbo
285 posts in 459 days
32 days ago
I have the Freud box joint cutter set, it cuts perfect 1/4 or 3/8 flat bottom dadoes. Two passes for 3/4, could be an alternative. I,m sure the dado set cuts just as well.
-- Tim: Remember, if it doesn't say Binford, someone else made it.
View Cato's profile
Cato
32 days ago
I was at Lowes today and looked at the clearance SD208’s. They had two, one with a silver ice coating and the other set was black. Both were marked at $75. Both sets looked like maybe they had either been used, or maybe they had just been there forever and appeared that way. Still if I am going to buy new I want it to at least look new, so I can make it old on my own. Now if they drop another $25 to get them off the shelf, well I may rethink that.
View 3fingerpat's profile (online now)
3fingerpat
907 posts in 561 days
32 days ago
I have had the SD508 for a number of years and am very happy with it’s performance, and would gladly purchase it again without reservation.
View hairy's profile
hairy
293 posts in 426 days
32 days ago
I have the SD208, and am satisfied with it. I have no experience with the other.
-- I'm a lumberjock and I'm ok, I sleep all night and I work all day!
View cstrang's profile
cstrang
1210 posts in 62 days
32 days ago
I have the Delta version of the DeWalt pictured above, havent had any problems with it and it gives a nice, clean cut.
-- A hammer dangling from a wall will bang and sound like work when the wind blows the right way.
