| Forum topic by alanealane | posted 782 days ago | 1930 views | 0 times favorited | 11 replies | ![]() |
782 days ago |
Topic tags/keywords: byrd shelix spiral cutterhead planer dewalt cnc Does anyone know where I can get DETALED, DIMENSIONED, DRAWINGS OF a DeWalt 733 planer cutterhead assembly? I am taking a few college courses in CNC programming/machining and our mill is supposed to be getting a Fourth Axis in the near future. I have plans to make my own ‘Byrd-style’ Shelix cutterhead for my DW733 (since Byrd tool doesn’t offer one to buy for this model). DeWalt Servicenet only has exploded assembly views, but I need to know dimensions WITHOUT having to dissect my own planer to measure what I need. ANY IDEAS? By the way—Fantastic Website!!!!!!!!!!!!!!!!! alane -- Lane Custom Guitars and Basses |
782 days ago |
I think that would be a direct violation of copyright. Bob -- A mind, like a home, is furnished by its owner |
782 days ago |
I DON’T want dimensions of a BYRD Shelix. I want drawings of a DEWALT straight-knife cutterhead (primarily for shaft diameters, bearing specs, keyways, shoulder distances, and thread callouts). Supplying that information will violate neither DeWalt or Byrd copyrights since there is no retail version of a spiral cutterhead for the DW733. I WILL DESIGN THE HELICAL PORTION OF THE CUTTERHEAD (since I do have a degree in CAD drafting and design.) All I want is to be able to know how to fit it into my planer housing. I’ll talk to some DeWalt Techs like you said, BUT IF ANYONE FEELS COMFY SHARING SOME TECHNICAL DATA, PLEASE DO! By the way, my DeWalt planer rotates the cutterhead @ 10,000RPM. Does anyone think that’s too fast for the spiral design??? —-Thanks!! -- Lane Custom Guitars and Basses |
782 days ago |
I read your request for info but I am not sure that your read my reply: Where did I suggest this? “I DON’T want dimensions of a BYRD Shelix.” Bob -- A mind, like a home, is furnished by its owner |
782 days ago |
Bob, I only wanted to make clear that I will IN NO WAY be violating copyrights on this project. From your suggestion that I would be, I felt the need to make myself clear. Sorry to be sour, but maybe I need to find a machinists forum somewhere….this being a metalworking thing. I really do appreciate the responses. -- Lane Custom Guitars and Basses |
781 days ago |
If anyone has any suggestions, please let me know. THANKS :) -- Lane Custom Guitars and Basses |
781 days ago |
Sounds like an interesting project. I love these cutterheads as they are so quiet. However for me I cannot justify the cost as I will probably not run 1000 board feet through my 735 in a year. I have actually gotten a line on a Powermatic 20 inch with a regular cutterhead for $1000. With that I can buy the shelix and just slip it in… however the powermatic just does not spin at 10000 RPM to begin with… Ill ask around. Drew -- Drew, Pleasant Grove, Utah |
781 days ago |
You sure want to spec the tungsten carbide you want to work with . Not saying no. just wondering where the “sweet spot” is? Bob -- A mind, like a home, is furnished by its owner |
781 days ago |
Most heleical cutter heads have those four sided 1/2” x 1/2” desposable knives, you get a “knick” and you simply rotate the small insert instead of replacing or grinding the big butt blade. rather impressive whenjointing or planing highly figured wood as there is little if any tear-out. A few places make just the head that you can interchange with quite a few jointers and planers….........big bucks but so is wasted burl from tear out. My guess…........no one is going to give you the plans to their technology for free Regards |
780 days ago |
You could change the gearing on your Dewalt cutterhead to reduce the spin since you are also making all of the parts of the cutterhead. -- What happens in the workshop stays in the workshop. No wait that doesn't sound right. Karson Southern Delaware karson_morrison@bigfoot.com † |
780 days ago |
GREAT SUGGESTIONS, THANKS. Bob has a good point about the low elasticity of carbide. I plan on purchasing the Byrd brand indexable carbide inserts, which are ground with a radius on the cutting edge, reducing lines on the wood from the corners digging in. I assume this is a high grade of carbide, but I’ll look into it. Karson-Thanks so much for the idea on changing cutterhead speed! My DeWalt planer is basically driven by a big 15A router motor (universal type that approaches 20,000 RPM). It drives the cutterhead via belt-drive. If I increased the pulley on the motor shaft by….oh….30%, that would bring the RPM down to around 7000RPM (is my math right?) on the cutterhead and still maintain a reasonable amount of torque. Maybe I need to also decrease the pulley diameter on the cutterhead (so that I can still be able to order a replacement belt in the future if need be—unless anyone can tell me how to make a belt longer. :D LOL). I have also considered a design where a STRAIGHT knife is bedded in the cutterhead at the proper shear angle—-What I mean is, instead of the knife being parallel with the axis of rotation, the knife has a slight angle with respect to that axis. I hope that made sense———WHAT DO Y’ALL THINK??? STILL CAN’T BEAT CARBIDE INSERTS, BUT IT MIGHT MAKE A NICE SHEAR CUT—I wonder if the blade has enough support at the ends of the cutterhead where it will protrude more. THANKS EVERYONE—-KEEP THE GOOD SUGGESTIONS COMING!! -- Lane Custom Guitars and Basses |
779 days ago |
I really am interested to see how this works for you. If it is a project for fun… like most things are in my shop… then go for it. If making this thing is a cost vs. benefit type situation… you may want to just buy another planer or you will be down to $3 per hour or less for your time after materials. (I am sure you know this but again… make sure you consider everything and it is all on the table upfront. Drew -- Drew, Pleasant Grove, Utah |
| Forum | Topics |
Woodworking Skill Share
2897 |
3908 |
255 |
940 |
219 |
Woodworking Trade & Swap
616 |
Coffee Lounge
2361 |
LumberJocks.com Site Feedback
522 |
