Jig saw or Rotary cutter?
Forum topic by Echofive posted 32 days ago 198 views 0 times favorited 7 replies Add to Favorites Watch
View Echofive's profile
Echofive
43 posts in 145 days
32 days ago
I’m trying to decide which I should get. I already have a bandsaw. Mostly I would use whatever I bought for cutting something inside a piece of wood… i.e. an internal cut, like if I were building a clock, I’d need this tool to cut out the hole for the clock face. Having the bandsaw I can make cuts on the exterior edges. I’d LOVE to have a scroll saw, but both money and space are the limiting factors there. So would you recommend a jig saw or a rotary saw? The 2 I’m looking at are within $10 of each other…
-- Chip, Massachusetts
View Peter O's profile
Peter O
1016 posts in 767 days
32 days ago
Chip, the cool thing about a rotary cutter is that you can put all kinds of different attachments in it and use it for sanding and cutting and routing … but if you’re going to cut a hole through wood more than a few 16ths of an inch thick, the rotary cutter is going to be slow going. A jigsaw will be a lot better at cutting holes, but cutting is all it does.
Have you looked on Craigslist for scroll saws? I see quite a few of them there.
-- http://www.north40custom.com -- http://north40studios.etsy.com --
View firecaster's profile
firecaster
482 posts in 311 days
32 days ago
There are a lot of accessories available for the rotary saw. I’ve not tried mine on solid wood. I have not been happy with it on plywood. That may be from the glue making it hard to cut and dulling the bit. Then when you hit a void; it jumps off line. Jigsaws seem, to me, easier to control and the blades last longer. But you are limited on the radius you can cut.
-- Father of two sons. Both Eagle Scouts.
Echofive
32 days ago
well I have a Dremel and it has been inCREDible… knowing what I know now about it I’d have paid 3 times as much as I did. I was under the impression that a rotary cutter is geared with enough power to actually do cutting… I guess perhaps I’m wrong. I was leaning toward the jig saw… but it’s limitations were its drawback. As far as the scroll saw, money isn’t near as limited as space. I rent the bottom floor of a house, so my table saw looks like a grill when I’m not using it. I nice grill cover covers it, and everything else (which is a surprising amount of tools) fits in a cabinet on the porch. So… for now… the scroll saw is out. :(
Thanks for your feedback fellas. All other feedback is welcome…
Peter O
32 days ago
What rotary cutter are you looking at? I’ve tried a ZipSaw, but they are really intended for sheetrock and panelling. There might be something tougher out there. You might also think about a trim router.
View TheDane's profile
TheDane
195 posts in 556 days
32 days ago
I have a RotoZip with a couple of attachments, but most of the time I reach for my Dremel tool.
-- The only place success comes before work is in the dictionary. -- Vincent T. Lombardi
View Gary's profile
Gary
576 posts in 326 days
32 days ago
Wish you were closer, I’d loan you my RotoZip to use so you could see for yourself what you think of it. I bought the big setup with all the attachments….almost never use it. It somehow just isn’t right for anything I do. That’s just me…..
-- Gary, DeKalb Texas
16684 posts in 470 days
32 days ago
Hey Chip
I know others like these tools but I don’t find much use for them. as far as you clock face goes you can buy a set of hole saws from HF for less the $10 that go up to 5”.
