copper to wood
« back to Woodturning forum
Forum topic by ChadRat6458 posted 07-28-2015 01:40 PM 808 views 0 times favorited 3 replies Add to Favorites Watch
View ChadRat6458's profile
ChadRat6458
89 posts in 1323 days
07-28-2015 01:40 PM
I want to make a big bead. I have some scrap copper sheet cut offs. I am thinking I could sandwich it between wood. I want to try cocobolo with cherry on both ends. The copper would be between the 2 woods. I want to drill a 3/4” in the middle. What is the best way to hold this together? Should I use some epoxy? Thanks.
-- WWW.SKYKAE.COM - Custome Wood Furniture and Signs WWW.FACEBOOK.COM/SkyKae.Kreations
3 replies so far
View Bill White's profile
Bill White
4907 posts in 3929 days
#1 posted 07-28-2015 01:47 PM
Yes, epoxy will work if ya rough up the copper a bit to give it some “tooth” to allow the epoxy to adhere.
Whatcha makin’?
Bill
-- bill@magraphics.us
View Nubsnstubs's profile
Nubsnstubs
1282 posts in 1698 days
#2 posted 07-28-2015 02:53 PM
Copper moves at a different rate then most wood. I know this as I made an octagonal table in 1984, and was asked to put 1/2” wide copper strips embedded in the joints. Looked good, but when I sanded it smooth, the copper flexed, but went back flat after cooling.
I saw the table about 5 years ago. It still looks good, but you can definitely see that the strips move with the temperatures. ........... Jerry (in Tucson)
View shipwright's profile
shipwright
7966 posts in 2766 days
#3 posted 07-28-2015 03:45 PM
I believe fish glue is used to adhere brass and pewter to wood in French marquetry. Fish glue allows a little movement. Search André Charles Boulle. He was a master of the art and used lots of brass.
