Tear-out with Incra I-Box
Forum topic by Jofa posted 07-27-2015 09:30 PM 1287 views 0 times favorited 6 replies Add to Favorites Watch
View Jofa's profile
Jofa
272 posts in 1863 days
07-27-2015 09:30 PM
Hey guys.
I’ve been using my Incra I-Box quite a bit and I like it very much. However, I’m finding that I’m getting tear-out on soft woods like pine.
I’ve fine-tuned the system so that my joints are aligned very well but the tear-out is an issue.
I made a supply of back plates out of 1/4” MDF but I’m finding that the tear-out is actually breaking through it. Should I possibly use 1/4” ply?
-- Thank you Lord for the passion and ability to make things from your creation.
4999 posts in 2518 days
#1 posted 07-27-2015 09:32 PM
You can, it will work fine. Is this on a table saw (?), maybe it’s time to check the blade.
View Jofa's profile
Jofa
#2 posted 07-27-2015 09:45 PM
Thanks Fred.
Yes, I’m using a Freud Diablo dado set. I really hope it isn’t the blade(s) as I haven’t used it daily or anything. It should still be sharp. Plus, the cuts on the way into each joint and on the edges are very clean. It’s just the way out.
View ksSlim's profile
ksSlim
1276 posts in 2915 days
#3 posted 07-27-2015 11:28 PM
I’ve been using 3/8” Borg ply for a backer board.
Seemed to stop the blowout.
-- Sawdust and shavings are therapeutic
View CharleyL's profile
CharleyL
222 posts in 3389 days
#4 posted 07-27-2015 11:56 PM
Try some 1/4 birch ply for backer boards. Also try moving the jig much slower over the saw blade. If pushed too fast the chip removal will be too aggressive and blow through the backer. I get the best box joints by using the Freud SBOX8 blade set on my Unisaw but I also use a Freud adjustable dado blade with very good results. They are designed to provide very square 1/4 and 3/8 joints with a minimum of tear-out. Moving the jig slower should make a huge difference.
Charley
View DocSavage45's profile
DocSavage45
8589 posts in 2867 days
#5 posted 07-28-2015 01:21 AM
Does tear tout occur without the Incra jig? Is this a wobble dado or the shim type. Any problems with tear out outside of this situation? Was this always a problem? That would help the problem solving.
-- Cau Haus Designs, Thomas J. Tieffenbacher
View Jofa's profile
Jofa
#6 posted 07-28-2015 04:55 PM
Hey everyone. Thanks for the replies.
@ Doc: I haven’t tried the dado without the jig (but I will). It’s a shim type (actually, it’s the Freud SBOX8)
It seems to have been an issue from the start
@ Charley and Slim: I’m going to try some different backer boards but I’ll also slow down. I’m using an old Craftsman (Atlas Press) table saw from like the 40’s (newer motor however) and it may not be powerful enough for the speed I’m going. I’m going to try tonight and see if I get similar results after slowing down.
