dead on square cuts
Forum topic by joez posted 07-26-2015 08:55 PM 1398 views 0 times favorited 13 replies Add to Favorites Watch
View joez's profile
joez
120 posts in 2811 days
07-26-2015 08:55 PM
Topic tags/keywords: miter slide saw
does any body have a sliding miter saw that have gives them spot on cuts?
13 replies so far
Gerald Thompson
877 posts in 2142 days
#1 posted 07-26-2015 09:49 PM
Mine is most of the time. I rely on a shooting board to get true 90d and 45d.
-- Jerry
View AandCstyle's profile
AandCstyle
2978 posts in 2165 days
#2 posted 07-26-2015 10:06 PM
Joe, I cut the 45 degrees for this project with a Hitachi SCMS and as you can see in Pic #6, they are dang near perfect. I think any MS can be adjusted to accurate, but the real challenge is how long a particular saw will hold that set. I am happy with mine. There are probably others that will do as well or, maybe even, better. Does this help?
-- Art
View TheFridge's profile
TheFridge
8902 posts in 1394 days
#3 posted 07-26-2015 10:11 PM
festool kapex
View Kazooman's profile
Kazooman
938 posts in 1860 days
#4 posted 07-26-2015 10:48 PM
I don’t own one, but I do have a regular Delta miter saw with a great 80 tooth blade that I have fine tuned over the years. I have always been happy with the angles on standard 45 degree meters and with the quality of the cut. I can put together a frame and not have any issues with the joints.
Then, on a whim, I bought a very old Lion Miter Trimmer off eBay. It was in terrific shape except for a few nicks in the blades. I had a try at sharpening the blades myself even though it took a long while to get the nicks worked out. They now cut ends as smooth as glass.
WOW! Once the stops were adjusted, the trimmer is dead on. The cuts are amazing. Some of the old hand tools still have their place is the shop. I guess a miter trimmer is not as “hand tool” as a shooting board and a plane, but the concept is the same.
My former ” dead on the proper angle” friend will now be the “rough cut” saw and the trimmer will finish the job.
View joez's profile
joez
#5 posted 07-26-2015 10:55 PM
the cuts are not long or deep, hope it does not have any play.
View joez's profile
joez
#6 posted 07-26-2015 10:55 PM
fret slotting
View rwe2156's profile
rwe2156
2803 posts in 1388 days
#7 posted 07-26-2015 11:39 PM
Jerry+1
Get you a shooting board that’s the best way to do it.
View exelectrician's profile
exelectrician
2327 posts in 2335 days
#8 posted 07-27-2015 12:53 AM
Makita 1013 ls quick to adjust the fence dead on and then it holds the accuracy.
My saw is dead on. I regularly plunge in 16” wide ply, flip it over, align the blade with the previous partial cut and finish the cut, dead on all the way through.
-- Love thy neighbour as thyself
View ColonelTravis's profile
ColonelTravis
1744 posts in 1802 days
#9 posted 07-27-2015 02:07 AM
I’m a guitar player, not a maker although I’ve had a chunk of alder for a telecaster sitting around for a while. With a miter saw I’d be more concerned about uneven depth instead of straightness. Did you consider hand sawing?
View lateralus819's profile
lateralus819
2241 posts in 1797 days
#10 posted 07-27-2015 02:25 AM
JoeZ- Stewmac sells a jig/saw to do slots by hand with a template. You could also make your own template and pick up a japanese saw.
TheFridge
#11 posted 07-27-2015 02:32 AM
What he said
View AlaskaGuy's profile
AlaskaGuy
3913 posts in 2217 days
#12 posted 07-27-2015 02:45 AM
What he said
- TheFridge
Who is he?
View joez's profile
joez
#13 posted 07-27-2015 03:09 AM
depth of cut is 1.40mm
