Tongue and Groove on a long board
Forum topic by TTJJ posted 07-25-2015 08:31 PM 1327 views 0 times favorited 7 replies Add to Favorites Watch
View TTJJ's profile
TTJJ
2 posts in 945 days
07-25-2015 08:31 PM
I need to tongue and groove the edge of a chest top to attach a breadboard edge. The chest top is 4-feet long; way too long for my router table. Router table is about 15 inches wide. I could never hold this big board steady to get a clean cut.
So how can I cut a tongue on both edges of this chest top? Also, my table saw is a contractor’s on-site saw. Way too small to cut a tongue.
TTJJ
7 replies so far
View waho6o9's profile
waho6o9
8100 posts in 2485 days
#1 posted 07-25-2015 08:32 PM
View dawsonbob's profile
dawsonbob
2742 posts in 1664 days
#2 posted 07-25-2015 08:56 PM
You may want to check out this set of matched bits. I have this set, and it works great.
I have cut a number of feet of board with this set handheld. The bearings make it pretty simple; just set your depth, and let ‘er rip.
Here’s the URL http://www.precisionbits.com/tongue-and-groove-router-bit-set-matched-2-bit-yonico-15221.html
-- Mistakes are what pave the road to perfection
View Yonak's profile
Yonak
986 posts in 1429 days
#3 posted 07-25-2015 09:24 PM
Not really a tongue and grove, maybe you can use this:
- waho6o9
Do you think these are photos of actual cutters ? It looks like the bearing guides would not be on the edge of the wood, unlike the ones in bob’s post.
dawsonbob
#4 posted 07-25-2015 09:39 PM
Do you think these are photos of actual cutters ? It looks like the bearing guides would not be on the edge of the wood, unlike the ones in bob s post.
- Yonak
Maybe the ones waho6o9 is showing need to be used with a guide, although that really doesn’t make much sense. I don’t know.
View Kazooman's profile
Kazooman
938 posts in 1860 days
#5 posted 07-25-2015 10:02 PM
I would assume that the groove is in the breadboard end so that should not be a problem. You can make the tongue with a simple straight bit in your router with a guide strip clamped to the chest top. One pass on each side.
View TTJJ's profile
TTJJ
2 posts in 945 days
#6 posted 07-25-2015 10:09 PM
The reply from Kazooman sounds like the best option. TTJJ
View bondogaposis's profile (online now)
bondogaposis
4611 posts in 2259 days
#7 posted 07-25-2015 11:47 PM
I usually make these on the table saw, but you say your saw is not big enough. You are left with using a hand held router or hand tools.
-- Bondo Gaposis
