Bed Slats
Forum topic by aussiechippie posted 35 days ago 169 views 0 times favorited 1 reply Add to Favorites Watch
View aussiechippie's profile
aussiechippie
13 posts in 70 days
35 days ago
Topic tags/keywords: bunks slat bowing bed poplar dovetail
I am currently designing a Bunk bed and would like to know opinions of what wood to use for slats and how to keep the side rails from bowing over time.
I have decided on 1.5” x 6” side rails on top and bottom bunks with dowels set into a cleat and slots at the end of each slat to prevent them moving. I have seen some ideas of dovetailing the slats into the side rail or an attached ledger, but wondered if anyone else had any ideas on how to stop the rails from bowing?
The beds will be made of Poplar and painted. Should I use poplar for the slats also? If not, what would you suggest (that won’t cost an arm and a leg)? And how thick/wide should I make them?
Thanks in advance for the help!
-- If at first you don't succeed... then skydiving's not for you...
View roundabout22's profile
roundabout22
78 posts in 980 days
35 days ago
I can’t tell you for sure what is right wood to use but I think poplar would be okay.
When I was a kid my brother and I shared bunk beds and the slats were 1×6 pine. They held up pretty good until the night my brother came crashing down on me.
Of course I’m not sure how much of that was from the fact that from our messing around we had happened to crack half the boards, and never mentioned it to anyone.
-- remember always measure once and cut twice
