Moulding knives vs. duplicator
« back to Woodturning forum
Forum topic by Matt Michaud posted 07-25-2015 03:38 PM 1017 views 0 times favorited 4 replies Add to Favorites Watch
View Matt Michaud's profile
Matt Michaud
35 posts in 2971 days
07-25-2015 03:38 PM
Has anyone ever tried using a moulding knife mounted to a crossfeed in order to quickly turn identical shapes? I am looking at a project that requires turning lots of 14” long spindle shapes which need to be made quickly and accurately. Obviously a duplicator could do this, but the moulding knife setup seems quicker in my head.
-- "Strength in Composites" http://sandwichtechskis.com/shop-dust-collection.htm
View helluvawreck's profile
helluvawreck
30163 posts in 2773 days
#1 posted 07-25-2015 03:58 PM
I have no idea what kind of quantity you want or what diameter that the spindles are but I have seen backknife lathes operation that might work for you.
We used as many as 10000 legs per week at one time. We thought about making our own legs but never ended up doing it.
The people who made our legs used Mattison lathes.
The type of mattison lathe that I am referring to had a set of centers that held the blank and revolved around the centers. There was a set of knifes mounted in a cutter head that moved into the wood blank. The knifes were ground to the profile of the leg. The finished leg was ejected and a new blank was fed into a locator where the centers would tighten up automatically and start revolving. These lathes would make a lot of legs in a days production.
helluvawreck aka Charles
View shipwright's profile
shipwright
7895 posts in 2704 days
#2 posted 07-26-2015 03:40 AM
I’ve used shaper cutters on the lathe for a smaller job. ....... worked well.
View pjones46's profile
pjones46
1000 posts in 2549 days
#3 posted 07-27-2015 01:38 PM
Most high production shops now use CNC equipped machines to turn spindles and legs. +1 to Paul M. but be careful as the tool sizes increases pressure needed to hold it as well as if the turning grabs the tool due to a wood flaw it can do alot of damage.
-- Respectfully, Paul
Matt Michaud
#4 posted 08-07-2015 01:36 AM
Thanks for all the input! While Paul proved it on a smaller-size blade, I am afraid pjones may be right about the danger of a longer tool’s cutting edge. Helluva, while your backknife lathe sounds ideal, its probably out of the budger. A tracer may be a middle-ground solution that we can rig up with equipment we have. Thanks again.
