Cornhole board finishing question
Forum topic by Skippy906 posted 07-25-2015 03:25 PM 1197 views 1 time favorited 7 replies Add to Favorites Watch
View Skippy906's profile
Skippy906
121 posts in 1857 days
07-25-2015 03:25 PM
Topic tags/keywords: question
I am in the process of making some cornhole boards. I primed, painted and striped the boards with semi-gloss paint. I am going to apply a decal to the center of the board. I know i can put poly acrylic over the entire design when its done.
My question is, I have raised paint lines where the tape for the design was applied. Should i sand the painted lines with very fine paper before applying the poly acrylic? Or put on a few coats of ploy then try and sand down the painted lines?
I know sanding will dull the finish of the paint if I sand before I poly it. But will the poly bring back the semi gloss shine to the sanded areas?
-- Making progress
7 replies so far
View crank49's profile
crank49
4028 posts in 2841 days
#1 posted 07-25-2015 03:51 PM
Around here nobody would notice a few raised paint lines.
Especially in the condition they are in when playing this game.
I just used gloss enamel paint on mine and they work fine.
View derrickparks57's profile
derrickparks57
129 posts in 1741 days
#2 posted 07-25-2015 06:51 PM
I would put a few coats of poly on then sand it. I’d be too afraid of screwing up the nice paint job and having to redo it. On another note, if I have friends over to hang out and play cornhole and one of them points out the raised lines, he can hit the road.
-- Derrick, Florida, DP Woodwerks
Skippy906
#3 posted 07-25-2015 06:55 PM
Thanks for the input Crank, and I know what you mean by the condition of the players. But I have a little OCD problem when it comes to finishing projects a certain way. I know the decal will pose a small problem and it will take quite a few coats of poly to get a smooth and even finish, that’s why I want to get rind of the raised paint lines also.
-- Making progress
Skippy906
#4 posted 07-25-2015 06:57 PM
Thanks derric, I was thinking the same thing. A few coats of poly then do the sanding with fine sandpaper. Then a whole lot more coats of ply and sanding in between.
-- Making progress
View cajunworkshop's profile
cajunworkshop
47 posts in 865 days
#5 posted 09-10-2015 02:11 AM
Skippy906 I want to build some of these. 2 questions where did u get the plans and where can I get collegiate decals for say LSU Tigers?
-- Cajun Workshop Greenville, SC
View Stewbot's profile
Stewbot
199 posts in 954 days
#6 posted 09-10-2015 02:44 AM
- cajunworkshop
I know your question is for Skippy, but I just built a pair and remember the dimensions. Regulation sized boards are 4’ long, 2’ wide rectangle. Drill a 6” diameter hole 12” in from the side, and 9” down from the top, this where the center of your hole needs to be. The back needs to be 12” high from the ground and front 3”. More detailed plans are probably readily available on the Internet, but those are the dimensions.
-- Hoopty scoop?
Skippy906
#7 posted 09-10-2015 11:43 AM
Where else would you get the dimensions, beside the American Cornhole Association….LOL. Yes, it is a website and I have even seen it on TV before. All joking aside, the boards are to their specs, 4’x2’, 1/2 plywood. The front of the board is 2 1/2 inches high and the back is 12” off the ground. (That is a 12 degree cut on the bottom of the legs) The hole is 6” round, and centered in the board and 9” down from the top.
As for the logo, I used a 12” decal I got from a shop dedicated for our team, or you can order one online I am sure. After I painted the boards and put the decal on, I put 5 coats of polyacrylic on them.
-- Making progress
