Solid Shelf Joinery in a Cabinet
« back to Joinery forum
Forum topic by Nugs posted 07-24-2015 06:50 PM 816 views 0 times favorited 4 replies Add to Favorites Watch
View Nugs's profile
Nugs
66 posts in 1964 days
07-24-2015 06:50 PM
Hello All,
I built a stereo stand last year and my wife liked it so much she wants me to build an end table quite similar. On the previous one I used plywood for the shelves, but this time around I would like to use solid wood if possible. I’m having trouble to figure out how to join the bottom shelf to the frame without causing wood movement issues. The plywood is dowelled to the front and back stretcher in this piece.
Do you guys have any suggestions? Here’s the pic of the first one, the bottom shelf is what is causing me a headache.
View rwe2156's profile
rwe2156
3036 posts in 1567 days
#1 posted 07-24-2015 09:20 PM
What I would do is put the shelf in a rabbet front and sides/anchor to front.
You’ll have to install a rail on the sides to accomodate.
Leave 1/8 – 5/32” gap at the back for movement.
Keep the long grain running side to side like a drawer.
View bondogaposis's profile
bondogaposis
4899 posts in 2437 days
#2 posted 07-24-2015 11:10 PM
Use cleats with slotted holes.
-- Bondo Gaposis
View BadJoints's profile
BadJoints
103 posts in 1175 days
#3 posted 07-25-2015 02:23 AM
+1 to rwe2156, I would drop it into a rabbet and only fix it to the front, so it’s free to expand at the back. Just make sure you orient the grain of the board correctly. On the other hand, you could do something really cool with the front edge, like a box joint or dovetails where the shelf and front rail meet.
I really like the grain in the panels of that piece. What species and finish did you use?
-- Producing furniture grade firewood since 1984
View Nugs's profile
Nugs
#4 posted 07-25-2015 01:15 PM
You ll have to install a rail on the sides to accomodate.
- rwe2156
Thanks, that makes sense and should work well in this application, I’ll have side rails for the bottom shelf so that should be no problem. I’ve decided to build a drawer to go where the top shelf is so I shouldn’t have any issues there.
Badjoints, the door panels are spalted birch. The rest is cherry (with oak ply), it’s all finished with a wiping varnish (Minwax Tung Oil).
