Sharpening Turning Tools
Forum topic by thelt posted 39 days ago 265 views 0 times favorited 6 replies Add to Favorites Watch
View thelt's profile
thelt
168 posts in 277 days
39 days ago
I have been sharpening my roughing gouge on my belt sander but that’s not getting the sharpeness I want. I also have one of Rocklers three piece sets that has, what I recently discovered, is a bowl turning gouge a parting tool and a skewing tool. All these need sharpening. I can’t afford a nice expensive sharpening jig. Anybody have any ideas that may solve my dilemma? I do have a 6” Bench Grinder if that helps. My belt sander is a Craftsman 6’X48” with a 9” disc sander.
-- There are three signs of old age. The first is loss of memory. I forgot the other two!
View rtb's profile
rtb
680 posts in 611 days
39 days ago
turning tools are usually sharpened on a grinder. I used to have the wolverine set which is pricey but lost it in a fire. I find that I can get satisfactory sharpness by hand but I think that the key is a fine wheel and slow speed. The grinder I use has variable speed and I believe it is a Task Force from lowes or Home Depot whichever carries that brand. the wheel I use is the fine one that comes with it. I do believe that exact angles vary some what with people probably due to differences in tallness and weather you or standing or sitting which I think only a few turners do. Hope that this helps.
View LesB's profile
LesB
555 posts in 341 days
39 days ago
Could you problem with the belt sander have anything to do with the coarseness of the grit? I would try a finer grit and see if that helps. I use a 6” grinder with a medium pink disk on one and a finer white disk on the other side and with practice it does the job.
If you search around there are lots of idea for “home made” devices to hold the tools for sharpening on a grinder. There was one posted just a day or two ago on this site.
-- Les B, Oregon
View ljsayat13's profile
ljsayat13
3 posts in 39 days
39 days ago
The ability to produce a sharp edge on a tool is a very important aspect of turning. Unfortunately there is even less uniformity of method in sharpening than there is in turning itself. If the opportunity can be taken to watch a variety of turners’ sharpening tools, either at demonstrations or on videos, it will be seen that some very different methods are used. Hardware Tools
View Sawdust2's profile
Sawdust2
1186 posts in 985 days
39 days ago
Try www.youtube.com and search for sharpening tools.
There a bunches of videos there.
View mski's profile
mski
360 posts in 878 days
39 days ago
Here is what I made,
Poor mans tool
poor mans tool2
Just get a fine white wheel and a diamond wheel truing tool, truing the wheel is very important I had a heck of a time before I did, I lost all my lathe favorites so if i can locate them I will post the plans I used.
Here is a good site for info, http://www.woodturningonline.com/Turning/Turning_articles.html
-- MARK IN BOB, So. CAL
thelt
38 days ago
Very nice jig, Mark. That’s something I think I can do. Thanks
