Hinge help
Forum topic by RootandBranch posted 07-24-2015 04:06 PM 787 views 0 times favorited 7 replies Add to Favorites Watch
View RootandBranch's profile
RootandBranch
241 posts in 1098 days
07-24-2015 04:06 PM
I got these. I need to make them into a clamshell type box. My idea is to cut in halfish with a very thin blade so as to not lose too much material, hollow out a cavity in the bottom section then hinge the top back to the bottom.
If’n it were you, how would you go about hinging the two very unsymmetrical pieces back together?
Thanks all.
-- Don, https://www.etsy.com/shop/RootandBranchGifts - http://facebook.com/rootandbranchgifts
7 replies so far
View waho6o9's profile
waho6o9
8187 posts in 2571 days
#1 posted 07-24-2015 04:10 PM
http://www.soss.com/invisible-hinge.html?cat=9
I’d install the hinges first and then sand and or shape to final dimension.
Good luck now.
View Hinge's profile
Hinge
79 posts in 1682 days
#2 posted 07-24-2015 04:11 PM
You’re asking for my help?
-- The Jesus is my Savior
View jerryminer's profile
jerryminer
923 posts in 1435 days
#3 posted 07-25-2015 01:33 AM
Or these:
Barrel Hinge
View GerryB's profile
GerryB
69 posts in 2576 days
#4 posted 07-25-2015 02:21 AM
How about a swivel vs a hinge? The top would just swing to the side.
-- The pursuit of excellence is gratifying and healthy. The pursuit of perfection is frustrating, neurotic, and a terrible waste of time. Edwin Bliss
View Nubsnstubs's profile
Nubsnstubs
1286 posts in 1724 days
#5 posted 07-25-2015 02:39 AM
Nice knees! ........... Jerry (in Tucson)
RootandBranch
#6 posted 07-25-2015 06:35 PM
Thanks everyone. My first thought was the swivel type since lining up the mortise or holes for the other types seems like it would be a bear on such uneven parts. However, I have some 12mm barrel hinges and may look at that a little closer.
Jerry, thanks. They actually look better than my own.
jerryminer
#7 posted 07-25-2015 08:01 PM
Dowel centers (or some equivalent) should make lining things up pretty simple
The bigger issue, IMHO, will be locating the hinges so you don’t get hinge-bound. But I think that with careful lay-out it can all work
