Geometry Problem
Forum topic by Don46 posted 1315 days ago 878 views 0 times favorited 8 replies Add to Favorites Watch
View Don46's profile
Don46
43 posts in 1775 days
1315 days ago
Topic tags/keywords: angles miters sled lap joint
I’m building a wine cellar with a wall of four built in units, the top one being a 7 foot wide x 10 inch high (external dimensions) horizontal cabinet. I want to insert diagonal “shelves” using 1×4 half inch oak boards to create a visually pleasing row of individual bottles above the main units.
I want to make the diagonal Xs come out evenly, so I have subdivided the cabinet into three sections, and have room for 3 Xs on each side and 4 in the middle. Each X on the side is 8.5 inches high by 7.5 inches wide on the sides, and 8.5 high by 7 inches wide for the middle.
I want to miter cut the ends and use a half lap joint at the center of the Xs.
How does one figure out the angles to set the miter saw to cut the ends?
For the half lap joints I am using my table saw. I know how to do this for 90 degree Xs: I use my cross cut sled on the table saw and cut out slots half way through the 1×4 oak.
What angle should I cut these lap joints?
What is the best way to do this for an angle cut that is not a 90 degree cut?
-- --Don, Columbia, SC
8 replies so far
View mics_54's profile
mics_54
581 posts in 1643 days
#1 posted 1314 days ago
Looks like a job for.. SKETCHUPMAN! Look! Up in the sky…it’s a bird with feathered texture! It’s a plane with animated landing gear! NO! it’s SKETCHUPMAN! Faster than a Intel Pentium 4 with 100 gigabytes of ram ..More powerful than a 3D locomotive with an exploded view! Able to draw photorealistic tall buildings in a single file!
Yes, it’s Sketchupman! ... strange visitor from another planet (Minni Sotie), who came to Earth with powers and abilities far beyond those of mortal Lumberjocks! Sketchupman … who can change the course of threaded helix, bend steel in his bare bender.rb, and who, disguised as DaveR, mild-mannered contributing writer for a great metropolitan woodworking magazine that shall go un-named, fights a never-ending battle for truth in documentation, just ice in his evening toddie, and the PanAmerican way! Mileage may vary. Offer void in some states.
-- Dan, Sterling Alaska, Before you criticise some one, walk a mile in their shoes...then you will be a mile away and you have their shoes!
Don46
#2 posted 1314 days ago
You guys are great! I’ve got a protractor and graph paper and have done a quick draw up.
In order to accommodate a wine bottle (about 3 inches in diameter) I need to flatten the X within the 7.5×8.5 rectangle, if you follow. One miter cut on each end with the long side in the corner. I’m no good with sketchup or I’d draw what I’m thinking.
I’m still not clear on how to execute the lap joint cuts.
thanks,
View Moron's profile
Moron
4442 posts in 2066 days
#3 posted 1314 days ago
Why complicate it. The wine wont care, neither will the consumer of said wine.
Why not make all lap joints 90 degrees and all ends at 45 degrees
Moron
#4 posted 1314 days ago
When I built my wine cellar I “changed it up”. One wall has vertical dividers, with horizontal “slots” using magic wires, another has square boxes put on 45 degree angles biscuited together, and another has section made into slots buch like your doing but for individual bottles. The little spaces that are left at the edges recieved a face frame to hide them. I put in a few shelves with faux stone back grounds.
then I drank all the wine and in the end…................I knew I couldnt afford to keep it full but it looks nice !!!
Don46
#5 posted 1314 days ago
I believe I can use Four 8.5 inch “square” Xs with 90 degree lap joints in the center bay, which has 35 inches inside dimension. The two side bays allow only 22 3/8 inches ID, and that is where I am having the problem.
The three bays are defined by two side cabinets below them, so that the stiles will be continuous from top to bottom. But as I’m writing this I’m already rethinking the need for three bays up top.
In a perfect world all of this designing would have been worked out exactly on paper (sketchup certainly) and all it would take is executing the design, but it seems like a lot of my design and construction decisions are being made on the ground as the process unfolds.
thanks Don
Don46
#6 posted 1314 days ago
Roman, I looked at your project gallery hoping to see your wine bins, but, alas, you had several other impressive projects, but not the wine cellar.
I will have small diagonals on top for individual bottles, and large diagonals on the side. In the middle I’m using shelves with wine cases made of pine and with decorative vineyard labels on the ends. There is a counter/bar on top of the middle case where I’ll have a few upright bottles.
I’ll post pictures when I’m finished.
thanks
Don
Moron
#7 posted 1313 days ago
sadly 3 out of 4 projects never get photographed but I shall remain steadfast in my belief to keep it
KISS
keep it simple…..............
Don46
#8 posted 1311 days ago
Looks good. I can’t link to the post at photo bucket for some reason. It asks me to sign in but then I don’t know how to locate your link.
I have diagonals on the sides but decided to go with individual slots across the top. I’ll post pictures rather than try to describe it.
Grand opening tomorrow evening. I bought 2 cases today but it barely fills two bins.
thanks everyone for your help.
Don
