How to Fasten facing trim to cabinets
Forum topic by Don46 posted 39 days ago 443 views 0 times favorited 18 replies Add to Favorites Watch
View Don46's profile
Don46
40 posts in 500 days
39 days ago
Topic tags/keywords: trim facing fastening nailing
I’ve built three tall cabinets, to be used as wine bins in a cellar, out of 3/4 inch oak ply. I have ripped 1×4 inch solid oak lumber 1 1/4 inches wide for the face trim. I’m planning to attach them now that the cabinets are bolted together and in place. Because the cabinets are not accessible from the back or sides now that they are installed, I need to attach the face trim from the front.
What is the best way to attach this? Can I use my brad nailer? Or should I use finish nails and a hammer + punch? This is not fine furniture but it looks nice and I want to make this finishing touch look right.
—Don
-- --Don, Columbia, SC
View DaneJ's profile
DaneJ
54 posts in 106 days
39 days ago
nails will work… you may want to use finishing nails, brads may not be long enough. Remember that brad/nail holes will have to be filled with putty… if you use finish nails and a hammer predrill holes to prevent splitting the oak face frames. Oak is notorious for splitting.
as you said, it is not fine furniture, how about a little glue and countersunk screws, then cover the screws with button plugs. use contrasting wood to make the plugs an accent…
you can also use pocket screws and glue, assuming that you can get to them from inside.
If the face frame is just show, and not needed to hang doors, you can just glue it on, use a c-clamp on the plywood then use a wedge to put some pressure on the face frame until the glue dries.
-- Dane, Fairview Pk, OH. The large print giveth and the small print taketh away...
17005 posts in 474 days
39 days ago
If you can get it aligned you can also use biscuits
View mics_54's profile
mics_54
431 posts in 368 days
39 days ago
18ga brads
-- Dan, Sterling Alaska, http://sullcon.homestead.com/ Before you criticise some one, walk a mile in their shoes...then you will be a mile away and you have their shoes!
View davidroberts's profile
davidroberts
243 posts in 383 days
39 days ago
since they are already attached, and if you don’t mind a few very small holes, then like mics_54 said 18 ga brads are the easiest way to go. Just dab them with stain to may the silver go away. if you plan to build more of these, or build cabinets in general, i’d recommend investing in a biscuit joiner. i was putting edge trim on plywood shelving tonight with biscuits.
One other item. I think small 1/8” or so dowels always look great and not to hard to install. I would use dowels that are darker than the wood. They have an old world charm. Like a good wine! just my $0.02 good luck
-- david roberts, houston area, "A little knowledge is a dangerous thing, but that has never been a problem for me."
25806 posts in 1298 days
39 days ago
Micro pins which are 23 ga. and glue. the pins will hold it tight until the glue dries.
mics_54
39 days ago
How the heck would you put 1/4 trim on with a bisquet?
Don46
39 days ago
Very helpful, thanks. The wood is pretty dark stained, so I’m not sure I could make dowels darker, and I am not sure I would want them lighter. I will run that one by my wife, who often has good instincts on what is going to look right.
I’ve got an 18 gauge nail gun and if I can hide the brads I may try that.
The wine is going to love all this.
View bentlyj's profile
bentlyj
790 posts in 367 days
39 days ago
”I’ve got an 18 gauge nail gun”
There ya go!!
The gun should sink the brad without having to use a punch. Fill the hole with putty and sand.
Someone had a good idea, ( I think it was Todd ) put some masking tape over the wood then shoot your nail through the tape and then put your putty in the hole over the tape. this way you don’t get putty into the grain all around your hole which could leave a spot if it doesn’t get sanded completely.
mics_54
39 days ago
If you putty it use color putty after it’s finished. Mix the color putty to match.
View Ed Elizondo's profile
Ed Elizondo
80 posts in 420 days
39 days ago
If have some of the sawdust from the same type of wood, you can mix it up with glue, make your own putty, and use the same technique that Bentlyj suggested. The sawdust will match your wood and should take the stain the same as the wood around it. Or you can go ahead and add the stain to your mix before you put it into the holes. I have done this and it has matched very close and hardly, if at all, noticeable. Use a 23 ga. pin nailer if you have one along with glue. If not use an 18 ga. Pin nailers cost about $60 at the Home Depot. Or you can Harbor freight and get one cheaper, but not as reliable for long term use.
-- Ed E. " Taking one board at a time "
davidroberts
39 days ago
mics_54, oops, read the post to fast and didn’t see the 1/4” trim. that would be one small biscuit,”0000”, haha
dennis mitchell
3791 posts in 1212 days
39 days ago
View Peter O's profile (online now)
Peter O
1027 posts in 772 days
39 days ago
I must be missing something … where does it say ¼” trim?? He says he used 1×4 (which is ¾” thick) and ripped it to 1¼” wide, so the trim is ¾” x 1¼”.
If it’s only ¼”, then just glue it.
-- http://www.north40custom.com -- http://north40studios.etsy.com --
View huff's profile
huff
1628 posts in 182 days
39 days ago
I didn’t find the 1/4” either. Sounds like he wants to mount 1 1/4” wide trim (he cut from a 1×4 solid oak.) That should make it 3/4” thick. I’m with the biscuits if you can align it. Glue and biscuit should be enough.
-- John @ Myrtle Beach
mics_54
38 days ago
OK I put my glasses on…calm down.
Don46
38 days ago
Yes, the trim is 1 and one quarter inch wide. I went ahead and used the brads and it seems to be working fine. I’ll finishthe trimming tomorrow I hope and then all it wants is a little more stain and top coat.
thanks
Don
View wasacop75's profile
wasacop75
7 posts in 53 days
24 days ago
This may be two weeks late,but, how about attaching from the inside? That way nothing shows on the outside.
-- No sawdust on the floor means no money in the pocket.
Rick Dennington
327 posts in 92 days
23 days ago
Ya’ll have got me so screwed-up, I can’t think straight. Which is why I think I’ll head to the kitchen for another glass of tea, and re-think this thing again.
Somebody needs to put on some glasses, or something !!! lol lol.
-- Remember--- one good turn-- gets most of the blanket!!!!
