the best time to use glue
Forum topic by Dan Hux posted 10-19-2009 01:37 AM 1009 views 0 times favorited 3 replies Add to Favorites Watch
View Dan Hux's profile
Dan Hux
577 posts in 3396 days
10-19-2009 01:37 AM
Topic tags/keywords: question joining
I’ve never tried any test with glue, maybe some of you guys already know answer to this. Is best to glue wood before or after primer. I’ve done both, but never tested the holding power of the glue after applying it on top of primer. It would make since that the glue would work best when using it on wood to wood surface rather than primed surface to wood surface.
Penny for your thoughts, I can’t afford much more than that.
-- Dan Hux,,,,Raleigh, NC http://whitdaniel.com
3 replies so far
View BeachedBones's profile
BeachedBones
201 posts in 3424 days
#1 posted 10-19-2009 01:42 AM
Wood glue holding strength is tested on raw wood as a standard measurement. My thoughts that paint between the glue and wood could only make the joint weaker.
-- You know.... I think that old wood needs to be furniture.
View RetiredCoastie's profile
RetiredCoastie
999 posts in 3205 days
#2 posted 10-19-2009 03:43 AM
Primer I believe acts as a sealer to seal the pores of the wood and with primer applied it would prevent or diminish the penetration of the glue into the pores which gives you a good bond.
-- www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops
117114 posts in 3599 days
#3 posted 10-19-2009 03:47 AM
I’m with the rest of the group don’t use primer before gluing.
