Joinery and wood expansion questions
« back to Joinery forum
Forum topic by devillier1 posted 07-24-2015 03:41 PM 880 views 0 times favorited 16 replies Add to Favorites Watch
View devillier1's profile
devillier1
11 posts in 1000 days
07-24-2015 03:41 PM
New poster here. Also New to woodworking.My question is how would you join the middle and bottom shelf on this piece to the legs? Taking in consideration expansion across the grain?
16 replies so far
View pjones46's profile
pjones46
1001 posts in 2605 days
#1 posted 07-24-2015 04:43 PM
Need a picture of what you are trying to do.
-- Respectfully, Paul
devillier1
#2 posted 07-24-2015 08:21 PM
devillier1
#3 posted 07-24-2015 08:22 PM
Sorry about that, forgot the pic.
View rwe2156's profile
rwe2156
2880 posts in 1443 days
#4 posted 07-24-2015 09:07 PM
I would notch mortise the leg corners.
Others may disagree but I don’t think its wide enough to worry about wood movement.
If the wood is dry and stabilized, you won’t get maybe 1/16” across a 12” width.
There is a chart you can look that up.
The other option is use banded plywood and don’t worry about it at all.
pjones46
#5 posted 07-24-2015 09:08 PM
It would appear that the shelf is attached to the box sides which forms the sides of the drawer using Kreg screws from the inside of the box.
devillier1
#6 posted 07-24-2015 10:36 PM
So if I use pocket screws from the sides screwed into to the shelf, and leave a small gap between the shelf and the legs (which I don’t like the idea of) should I even worry about expansion?
View bondogaposis's profile
bondogaposis
4680 posts in 2313 days
#7 posted 07-24-2015 10:43 PM
So if I use pocket screws from the sides screwed into to the shelf, and leave a small gap between the shelf and the legs (which I don t like the idea of) should I even worry about expansion?
- devillier1
Only if you use plywood, then the gap will serve no function. The piece of furniture in the photo is almost certainly made from composites either plywood or veneered particle board in which case wood movement is a non issue. If you intend to adapt this design to solid wood construction then you have some thinking to do. If the sides are solid wood then they are going to have to “float” as in frame a panel construction. If I were to make this project I would use plywood except for the top, legs and drawers, that would greatly simplify the construction and eliminate wood movement issues. If I were to make it from solid wood I would re-design it from scratch using frame and panel for the sides and also use frame and panel for the shelves.
-- Bondo Gaposis
View SawduztJunky's profile
SawduztJunky
71 posts in 1120 days
#8 posted 07-24-2015 10:50 PM
Pocket screws bottom side of shelves. The expansion/contraction would be such an insignificant amount, you need not worry.
-- I don't think I'm ever more "aware" than I am right after I hit my thumb with a hammer. Questions about solid surface? Just ask. http://www.swiiitch.portfoliobox.net
devillier1
#9 posted 07-24-2015 11:15 PM
Well using plywood is definitely an option being that I’m painting everything but the top. How’s does endgrain on plywood look painted?
Woodworking was so much easier before I was aware of/considered wood expansion.
pjones46
#10 posted 07-24-2015 11:19 PM
Band the plywood with solid wood.
bondogaposis
#11 posted 07-25-2015 12:38 AM
Like crap. Edge band, then paint.
-- Bondo Gaposis
View Blackie_'s profile
Blackie_
4879 posts in 2474 days
#12 posted 07-25-2015 02:46 AM
The way I would do it, the same way I did my live edge tables, make mortise and tenon runners between the legs and use the Cleat method shown in my project below.
Making furniture no matter what it’s for you want it made strong enough to have sex on it metaphorically speaking.
http://lumberjocks.com/projects/104610
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs
devillier1
#13 posted 07-25-2015 02:50 AM
Thanks fellas. Blackie can you repost that link? It doesn’t work.
devillier1
#14 posted 07-25-2015 03:35 AM
The link works now, I definitely plan on using cleats on the hardwood top. It’s the middle and bottom shelves I was asking about.
Blackie_
#15 posted 07-25-2015 11:38 PM
Use the same method for all surfaces, the bottom shelf I also used cleats.
