dyeing wood for marquetry
Forum topic by tom posted 40 days ago 318 views 0 times favorited 7 replies Add to Favorites Watch
View tom's profile
tom
6 posts in 1018 days
40 days ago
I would like to make some realistic leaves for a double bevel marquetry project. I will be making my own 1/16 ” veneer. Is there a way to dye the wood green to penetrate into the veneer so I can make leaves that will stay green after scraping the surface flush with the rest of the inlay? alternatively is there a wood that is naturally green that I am not aware of? Thanks for any help
tom
-- tom
View Julian's profile
Julian
695 posts in 423 days
40 days ago
For dying all the way through you’ll want to look into vacuum infusion. Here's a great website for learning how to do it.
-- Julian, Park Forest, IL
View SteveMI's profile (online now)
SteveMI
225 posts in 192 days
40 days ago
Julian – I looked at the article and video on Joe’s site, but don’t grasp the process. What part does the vacuum play in the dye penetrating the wood? Is the vacuum on one side and the dye on the other? I could be completely dense here.
Steve.
View Sawdust2's profile
Sawdust2
1186 posts in 985 days
40 days ago
Wood is porous.
By immersing the wood into the dye solution and then attaching the vacuum it will draw the dye solution into the pores as the vacuum sucks the air out of the wood.
Obviously, the more porous the wood, like balsa, or the thinner the slice, the more the dye will be infused into the wood.
If your leaves are small enough you can put them in a pint or quart jar, without the lid, and put that inside a gallon pickle jar. Attach your vacuum to the pickle jar and wait a day or so.
Or you can buy white veneer and just let is soak in a green solution (diluted food coloring) for about 30 seconds
Or you can buy green veneer. Paul Schurch sells green veneer.
Lee.
View tomd's profile
tomd
216 posts in 668 days
39 days ago
You can do a search for alowood it comes in several colors, Rockler used to carry it. It is real wood but colored all the way through.
-- Tom D
View tom's profile
tom
39 days ago
thanks for all the info, since I don’t have a vacuum pump I’ll try looking for green veneer
tom
-- tom
View Billp's profile
Billp
333 posts in 1097 days
37 days ago
You can also get dyed veener at B&B rare woods
-- Billp
View daveintexas's profile
daveintexas
338 posts in 774 days
32 days ago
One tip I read from a very good woodworker is to use Rit dye.
I have not tried it, but it makes sense.
-- MISSION FURNITURE-My mission is to build furniture
