Brass corners?
« back to Coffee Lounge forum
Forum topic by Xtreme90 posted 10-18-2009 07:38 PM 1268 views 0 times favorited 2 replies Add to Favorites Watch
View Xtreme90's profile
Xtreme90
193 posts in 3216 days
10-18-2009 07:38 PM
Topic tags/keywords: sealer on brass corners question
Hi everyone,
I have a question about sealing over brass corners? I’m installing a set of 4 brass corners on a set of drawers I made. I’m applying a minwax polycrylic water based clearcoat finish. Can I apply this over the brass corners? Or will it just flake off. I’ve seen on other pieces of furniture that has these brass corners they seem to brown and loose the shinyness.
Thanks!
-- "I don't cut wood. I machine it!" G.M. The wood machinest
2 replies so far
View SteveB's profile
SteveB
57 posts in 4081 days
#1 posted 10-18-2009 08:38 PM
When I used to repair furniture for a furniture store, we used clear gloss spray lacquer for this application. Spray lacquer covers a multitude of sins. :)
I would finish the wood, seal the metal parts with the spray lacquer, and finally apply them to the piece after everything is dry. You can add a little more spray lacquer at the end if you want to seal over scratches from the nailing process.
The brass parts most likely come with a coat of lacquer (or something similar) already.
-- Steve B - New Life Home Improvement
117115 posts in 3600 days
#2 posted 10-19-2009 05:50 AM
good approach
