| Forum topic by Bruce | posted 43 days ago | 218 views | 0 times favorited | 7 replies | ![]() |
43 days ago |
I have a single panel door of solid fir that has a hole in the flat panel. Is there a way that I can get the door joints apart on the top and bottom so I can replace the panel? Another alternative would be to cut one side of the door frame off, then remove and replace the panel. The door frame joints seem pretty tight still so getting them apart presents a problem. Thanks in advance for any advice! -- Bruce Ebling |
