Cabinet building/design question
Forum topic by Betsy posted 38 days ago 248 views 0 times favorited 6 replies Add to Favorites Watch
View Betsy's profile
Betsy
2386 posts in 790 days
38 days ago
Topic tags/keywords: bathroom cabinet over-the-toilet cabinet
I’ve got a small bathroom with a 28.5” “alcove” where the toilet sits. I’d like to put a cabinet above the toilet.
I’m thinking that since the space is so narrow – that instead of making a cabinet that I should just attach runners along the wall and attach a face frame to the runners – to make essentially a built-in cabinet. What do you think?
Also, 1) how high above the toilet are cabinets usually placed?
2) generally how tall are over-the-toilet cabinets?
3) since this is over a toilet – how deep should I make it?
Thanks in advance.
View DaveR's profile
DaveR
1524 posts in 615 days
38 days ago
Hi Betsy,
I think you could get away with doing what you suggest. You might add horizontal cleats for the top and bottom of the cabinet and then add the face frame. As to depth and height, I would make it so that a tall person seated on the toilet wouldn’t bang their head. For depth I would go with maybe 14 to 16”.
-- Until you spread your wings, you'll have no idea how far you can walk.
Betsy
38 days ago
Thanks Dave!
View Thuan's profile
Thuan
203 posts in 712 days
38 days ago
I would build box 28” x 30” tall out of 3/4” plywood. This gets mounted to the studs on the wall. There is enough space left on each side to glue and brad the face frame that you had scribed to the contour of the two sides. This gives you a perfectly square box that fits perfectly wall to wall in a usually not so square space. The depth of the cabinet would be in line with the toilet seat cover in the up position. This guarantees no one bumps their head and has a custom detail to the measure. The doors would be made after the box is fitted to the space.
-- Thuan
dennis mitchell
3789 posts in 1209 days
38 days ago
Betsy you have described a built in cabinet, that is old school,, stick built cabinetry. The only draw back would be not having wood/melamine walls for your cabinet. You still need to build shelves.
A) about 54 inches
B) They can be short or run all the way to the ceiling.
C) Less than 12 inches, If you want large towels in it I’d make it 12 deep.
TopamaxSurvivor
3017 posts in 570 days
38 days ago
The builders up one above one of our toilets. It is 8” deep and 26” above the water tank. It has never been close to being in the way. I don’t think 12” deep would be a problem at that height, maybe if it were lower.
Betsy
38 days ago
Thanks for the ideas guys!
