When is a router bit too dull?
Forum topic by oldnovice posted 07-22-2015 04:30 AM 3090 views 0 times favorited 11 replies Add to Favorites Watch
View oldnovice's profile
oldnovice
6900 posts in 3394 days
07-22-2015 04:30 AM
Topic tags/keywords: router question
I was doing an inventory of my router bits to get an idea of how many I have and, at the same time, to categorize them; i.e. carbide/HSS, piloted, and edge forming when it came upon me that some of these bits are very old and may/may not be good (not sharp) any more!
My question is, what is a simple way to determine if a bit is sharp enough or worn out?
11 replies so far
View pjones46's profile
pjones46
1001 posts in 2669 days
#1 posted 07-22-2015 04:52 AM
You may not be able to tell if a router bit is dull just from looking at it. You may need to check the bit’s cutting performance and ease of use – dull bits will be difficult to move through material, even softwoods.
Dull cutting edges will burn the surface of the material rather than slicing through it.
A bit that leaves a rough finish when it usually leaves a smooth one is also likely to be dull.
If your router bit is displaying these characteristics, it is probably time to think about resharpening.
-- Respectfully, Paul
View TheFridge's profile
TheFridge
9608 posts in 1512 days
#2 posted 07-22-2015 05:10 AM
Ditto
View DeLayne Peck's profile
DeLayne Peck
545 posts in 2228 days
#3 posted 07-22-2015 09:33 AM
Hans,
I usually test my router bit in the same material I am going to shape. I am looking for the pace and speed setting I can move at to get a smooth profile with burning.
There are lots of fine diamond hones on the market. I like to give bits a shot of pitch remover and a few laps with the diamond stone.
-- DJ Peck, Lincoln Nebraska. Lord, keep your arm around my shoulder and your hand over my mouth.
View Dutchy's profile
Dutchy
2987 posts in 2195 days
#4 posted 07-22-2015 12:02 PM
I agree what is said above but when a TC router bit on his cutting top is changing color from “black too white” he,s dull.
-- https://dutchypatterns.com/
View dhazelton's profile
dhazelton
2771 posts in 2323 days
#5 posted 07-22-2015 01:45 PM
You can usually feel the cutting edge to see if it is sharp or is smoothed over. I have a Drill Dr and it works great for twist bits. Spade bits I usually use a small diamond file on.
View madts's profile
madts
1862 posts in 2366 days
#6 posted 07-22-2015 02:42 PM
I was taught, that if the carbide or HSS can scratch you nail easily you are in good shape.
quick rule of thumb nail :)
Madts.
-- Thor and Odin are still the greatest of Gods.
View Bill White's profile
Bill White
4949 posts in 3987 days
#7 posted 07-22-2015 02:48 PM
I’m with Madts. I also touch ‘em up with a diamond paddle.
Bill
-- bill@magraphics.us
View moke's profile
moke
1182 posts in 2803 days
#8 posted 07-22-2015 04:01 PM
+1 with the hone….I have extended the life of many bits. At certrain point though, they are done.
Mike
-- Mike
TopamaxSurvivor
18290 posts in 3702 days
#9 posted 07-22-2015 06:00 PM
Madts.
- madts
That is my “rule of thumb” for most sharp tests ;-)
oldnovice
#10 posted 07-26-2015 06:10 AM
Thanks everyone!
After checking my 60+ older bit I have no thumbnail
View robscastle's profile
robscastle
5102 posts in 2230 days
#11 posted 07-26-2015 07:36 AM
Yeeee….dont do it with the machine on!!
Plus you can also check it in the light if there is a shiny edge or refelection its time to sharpen.
Also dont forget to check the bearing for free movement and add a couple of drops of oil for good measure, they are only small but work hard!
-- Regards Rob
