Bringing out the grain
Forum topic by arlodaniel posted 07-21-2015 08:15 PM 1473 views 0 times favorited 8 replies Add to Favorites Watch
View arlodaniel's profile
arlodaniel
7 posts in 1647 days
07-21-2015 08:15 PM
Hi all,
A couple years back I stained this fir table with a technique that I happened onto by mistake—but was extremely happy with the results:
Essentially, I applied a very dark stain, and then sanded most of it off, leaving just the grain lines stained. (Of course then I did more to finish it: BLO, wax-free shellac, poly.)
I’d like to replicate this look of extreme grain lines with a new piece of furniture I’m working on, but it’s incredibly labor intensive—and goes through a massive amount of sandpaper, as the stain builds up on it immediately.
Any suggestions for achieving a similar effect without massive amounts of post-stain sanding? I have a feeling that there’s a much easier way.
Thanks for any and all thoughts!!
arlo.
8 replies so far
View JoeinGa's profile
JoeinGa
7736 posts in 2006 days
#1 posted 07-21-2015 11:36 PM
At first glance I thought you had burned it with a torch. Try that on a piece of pine. Just keep the torch moving and then sand lightly. You’ll see similar effects.
View gfadvm's profile
gfadvm
14940 posts in 2689 days
#2 posted 07-21-2015 11:46 PM
I had the same thought as Joe. Looked like it had been torched to m
arlodaniel
#3 posted 07-21-2015 11:50 PM
Interesting idea! I just tried it on a sample of wood (albeit with a small lighter), and it looks very promising; I may indeed try this out. Thanks!
View Daruc's profile
Daruc
460 posts in 1131 days
#4 posted 07-21-2015 11:53 PM
What type of wood are you using for the new pc of furniture?
Pine or fir works OK with the torch, other woods, maybe not so much.
Obviously do a sample pc first.
Edit: I was typing while you posted, I see you tried a sample already.
Moot point!
arlodaniel
#5 posted 07-22-2015 12:19 AM
It’s a couch I’m making from pallets, so the type of wood varies.
(This sort of idea)
But I’m fine with some variation; guess I’ll just do some testing.
View Luthierman's profile
Luthierman
221 posts in 1086 days
#6 posted 07-22-2015 12:52 AM
What about using a scraper instead of sand paper? That never clogs.
-- Jesse, West Lafayette, Indiana
arlodaniel
#7 posted 07-22-2015 12:58 AM
I got a card scraper exactly for that reason—but somehow I can only ever get it to produce a few pathetic scrapings (and two very sore thumbs). I’ve tried to follow instructions for sharpening, with a burnisher and mill file, but feel like I must be missing something… Or maybe it only works well on certain types of wood?
View TheFridge's profile
TheFridge
9468 posts in 1485 days
#8 posted 07-22-2015 01:17 AM
Don’t forget to hone the edges of the scraper.
