Help me make or buy this brass part.
« back to Hand Tools forum
Forum topic by Combo Prof posted 07-21-2015 04:53 PM 897 views 0 times favorited 16 replies Add to Favorites Watch
View Combo Prof's profile
Combo Prof
3436 posts in 1241 days
07-21-2015 04:53 PM
Topic tags/keywords: question brass marking gauge part
This is the brass plate of my Stanley 65 marking gauge. I need the same part to restore a vintage Stanley 77 mortise marking gauge. Its about 1/4” by 1/16” by 1-1/4” with raised ends.. I am not a metal worker. How do I make it or where can I buy one?
-- Don K, (Houghton, Michigan)
16 replies so far
View mahdee's profile
mahdee
3870 posts in 1731 days
#1 posted 07-21-2015 05:01 PM
View DKV's profile
DKV
3940 posts in 2467 days
#2 posted 07-21-2015 05:02 PM
In focus would help.
-- This is a Troll Free zone.
View hhhopks's profile
hhhopks
651 posts in 2340 days
#3 posted 07-21-2015 05:06 PM
Get some brass bar/plate and get the files out.
-- I'll be a woodworker when I grow up. HHHOPKS
Combo Prof
#4 posted 07-21-2015 05:25 PM
- DKV
I tried a couple of times best I could do.
- hhhopks
That was my thought but could not find thick enough in town.
http://www.amazon.com/Brass-Sheet-010-FS-10-1/dp/B0006MZOB2
- mrjinx007
Not thick enough. Unless I fold up the ends some how. Needs to be I think 1/8” by 3/8” by 10/8”
Original looks cast to me.
View Redoak49's profile
Redoak49
3193 posts in 1952 days
#5 posted 07-21-2015 05:53 PM
I would bend the ends over making them longer than needed to make the bend easier. Then use a file and or Dremel tool to shape it. Brass is easy to cut and file….it will take some time but is doable.
Combo Prof
#6 posted 07-21-2015 06:09 PM
- Redoak49
O.K. I’ll try that. I’m assuming any kind of file will work. I have some have some HF diamond files as well as the usual bastard files. Do I score the brass be for bending?
View Hammerthumb's profile
Hammerthumb
2835 posts in 1938 days
#7 posted 07-21-2015 07:43 PM
Don’t need to score it. If you need some 1/8 thick brass, I have some I can send. PM me with your address.
-- Paul, Las Vegas
Combo Prof
#8 posted 07-21-2015 11:11 PM
Don t need to score it. If you need some 1/8 thick brass, I have some I can send. PM me with your address.
- Hammerthumb
I may do that it would come out more true if I carved out the piece from thick stock. But I got some thiner stock now and will try the bending. One though about the scoring is that if I score and heat I can get a more square bend. But first I’ll try it with out such treatment and see. As usual I don’t really know what I am doing until I jump in and get my feet wet. But to avoid at least some mistakes I ask lots of questions first.
View REO's profile
REO
928 posts in 2037 days
#9 posted 07-22-2015 12:20 AM
depending on the brass stock it wont t take a sharp bend make a hollow in a piece of wood and cast the lump from brazing rod and then get out the fiies.
Combo Prof
#10 posted 07-22-2015 12:39 AM
- REO
Sorry to ask but how do I cast the brass. I.e. How do I melt it? What do do I need to do this?
View KevinL's profile
KevinL
33 posts in 1313 days
#11 posted 07-22-2015 12:42 AM
Anneal the brass first by heating it up with a torch and quench it in water. Brass is going to work harden very fast when you bend it. Chances are it’s hard from the rolling process in the manufacturing process. You may have to do it again as you work with it.
Then break out the files and it won’t take very log at all.
-- KevinL
KevinL
#12 posted 07-22-2015 12:47 AM
Also before you start using the files, run a piece of chalk over the file and fill all of the teeth with the chalk. It will help keep the file from pining (material caught in file teeth).
Have a file card to clean the file up, re apply the chalk, and keep filing.
After you are done with the file, you can polish it all up by using several grits of emery paper.
-- KevinL
Hammerthumb
#13 posted 07-22-2015 12:48 AM
Don- I’ll send enough so you can experiment with a few techniques. Agree with the annealing process above.
-- Paul, Las Vegas
View dhazelton's profile
dhazelton
2754 posts in 2260 days
#14 posted 07-22-2015 12:58 AM
Go to a place that makes trophies and plaques and buy the brass there. Or just buy a new marking gauge – probably much easier.
View upchuck's profile
upchuck
540 posts in 1628 days
#15 posted 07-22-2015 02:42 AM
Combo Prof-
You could cast it… but that is a whole nother ball of wax. What are you going to use for the mold? Wood? I wonder if the temperature of the melted brass would exceed the temperature of wood combustion. I suspect so. Also what do you have to to heat the brass to melting point? And to hold liquid brass for pouring? I also suspect that the filing/grinding of your raw casting would equal or exceed the same if you reduce a piece of brass stock. I’ve recently begun to work on some raw bronze castings and while a different material it is labor intensive.
Good luck and that nice mortise gauge is worth preserving.
chuck
