Forum topic by StaceyD | posted 07-21-2015 01:12 PM | 1329 views | 0 times favorited | 9 replies | ![]() |
Topic tags/keywords: mesquite finish epoxy I’m working on a new dining table and it’s the first time I’ve done a project quite like this. I’m using some nice mesquite and I plan to fill the voids with an epoxy to level it out. Does anyone have any advice on what finish I should use? This is the first time I’ve used mesquite in a project, my initial thought was to finish it with a poly top for protection but I’m not sure what else I should be using in lieu of/in addition to this to enhance the natural qualities of the wood. |
9 replies so far
#1 posted 07-21-2015 02:32 PM |
I am not sure if poly will go over epoxy. You can epoxy finish the whole thing. -- earthartandfoods.com |
#2 posted 07-21-2015 03:48 PM |
I thought I had read that people have used poly over epoxy. One thing I don’t do though is sand to an extremely high grit. Usually 150-180 is as high as I will go and then 220 for between coats. Maybe using something in that grit range will help the poly attach better to the epoxy versus sanding 220 or higher to start? |
#3 posted 07-21-2015 04:03 PM |
I’ve used Arm R Seal over epoxy in mesquite many times. |
#4 posted 07-21-2015 04:05 PM |
Based on this project using pecky cypress: I was thinking of using a tung oil finish before applying the poly, I don’t think there’s a problem doing that? |
#5 posted 07-21-2015 04:33 PM |
There is a New Yankee Workshop episode that covers Mesquite and an Oil finish at the end. |
#6 posted 07-21-2015 06:38 PM |
I built a bed for my daughter using oak that had a couple of open knots. She like the character of the knots. I tried that Gorilla glue 2 part epoxy, it left a couple of air bubbles. I settled on a 2 part clear resin filler. We sprayed a water based lacquer and it’s held up well for the last 3 years. |
#7 posted 07-21-2015 06:47 PM |
Do you remember what grit you sanded to before spraying? |
#8 posted 07-21-2015 09:00 PM |
Tint the epoxy black (I use lamp black Tints All), fill and sand smooth and flush. I usually sand to 180 to 220 grit. Apply stain if you would like then follow up with polyurethane. It is totally compatible and looks great. -- Roger M, Aiken, SC |
#9 posted 07-22-2015 12:15 AM |
I have done both Spar Urethane and poly over epoxy with no problems. Sanded to 320. -- " I'll try to be nicer, if you'll try to be smarter" gfadvm |
Forum | Topics |
Woodworking Skill Share
12027 |
Woodturning
2105 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4901 |
6691 |
28041 |
CNC Woodworking
211 |
Hand Tools
5404 |
Jigs & Fixtures
1417 |
Wood & Lumber
6229 |
1387 |
Focus on the Workspace
2153 |
1186 |
Woodworking Trade & Swap
4754 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8842 |
