Finish Recommendations for Maple Plywood (BORG)
Forum topic by Kurt T. Kneller posted 07-21-2015 12:57 PM 746 views 0 times favorited 5 replies Add to Favorites Watch
View Kurt T. Kneller's profile
Kurt T. Kneller
126 posts in 1598 days
07-21-2015 12:57 PM
I am in the process of building a router table and I am using maple plywood for the cabinet.
The plywood is from the HD and not the greatest, but is for the shop. I would like to put some type of finish on it but I have heard a lot of horror stories. I am looking for something with a slight amber color and some protection against moisture and the wear-n-tear of a garage workshop. I also would like something easy and quick so I can get it up an running. Should I use and amber shellac, wipe-on poly? What brand would you recommend?
Any advice would be greatly appreciated.
Thanks in advance!
-- Start with ten, end with ten.......
5 replies so far
View Kazooman's profile
Kazooman
1265 posts in 2187 days
#1 posted 07-21-2015 01:08 PM
How about Danish Oil?
5232 posts in 2728 days
#2 posted 07-21-2015 01:47 PM
Pretty much anything you want to use will be fine…I didn’t even finish mine and it’s 16 years old now. If you have a finishing technique that needs fine tuning, use the cabinet to practice that technique.
View timbertailor's profile
timbertailor
1594 posts in 1658 days
#3 posted 07-21-2015 01:56 PM
I finished my maple plywood router table in a light shaded polyurethane.
The humidity in Houston is brutal. I wanted something to protect it without changing the color too much.
View RogerM's profile
RogerM
799 posts in 2633 days
#4 posted 07-21-2015 01:59 PM
If you want the amber color use Mosers medium walnut aniline dye followed by a coat of Seal Coat then 3 coats of diluted polyurethane ( 1 part poly to 1 part mineral spirits).http://lumberjocks.com/assets/pictures/projects/287762-438x.jpg
-- Roger M, Aiken, SC
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2604 days
#5 posted 07-21-2015 02:01 PM
The panels on these doors are BORG maple plywood, and are slightly yellower than they appear in the picture. Finish was a few coats of Arm-R-Seal wiped on, buffed out with paste wax and 0000 steel wool. Doesn’t get much easier or more idiot-proof. This project was completed 2 years ago, I really should get some better pictures.
