need help repairing my bandsaw
Forum topic by BurlyBob posted 07-21-2015 01:09 AM 712 views 0 times favorited 4 replies Add to Favorites Watch
View BurlyBob's profile
BurlyBob
5249 posts in 2172 days
07-21-2015 01:09 AM
So a number of years ago I picked up a Dewalt 12” band saw. Actually it’s an Atlas 912. I’m in the process of getting tuned up like it should be. I’ve replaced all the bearings, a new blade, new tires arrive later this week. What I really need is a new tension spring. I checked OWWM and a couple of other websites and forum sites. They indicate that the Carter replacement springs are a little to strong for this saw. If anyone can give me a lead where to get a new spring it would be greatly appreciated.
Thanks,
Burly Bob
View MrUnix's profile
MrUnix
6355 posts in 2105 days
#1 posted 07-21-2015 01:20 AM
I can see how a spring might be too soft, allowing it to bottom out before allowing enough tension… but I’m having a hard time imagining how it could be too strong – you just don’t need to crank down on it as much as you would with a stock spring. Also, what’s wrong with the spring that is on there now (if there is one)?
BurlyBob
#2 posted 07-21-2015 01:38 AM
Yeah, Brad I felt that way also, so I measured the bolt. It’s 2 1/2” long, the shortest Carter bolt is 2 1/2”. I very well may settle for that and be done with it. Just thought I’d pull the trigger and see what I could find out from any other Jocks.
View crank49's profile
crank49
4029 posts in 2877 days
#3 posted 07-21-2015 07:10 AM
McMaster Carr sells springs of all sizes and strengths.
But, they wouldn’t call it a specific purpose, as in “band saw blade tension spring”.
You would have to know the type of coil, O.D. of coil, diameter of wire, etc.
BurlyBob
#4 posted 07-21-2015 03:20 PM
Thanks Mike. I’ll look into it today. Got to do some weed killing first thing.
