Outdoor finish for white oak Adirondack chairs?
Forum topic by ColonelTravis posted 07-20-2015 10:43 PM 1281 views 0 times favorited 12 replies Add to Favorites Watch
View ColonelTravis's profile
ColonelTravis
1801 posts in 1920 days
07-20-2015 10:43 PM
Topic tags/keywords: spar varnish adirondack
Working on Adirondack chairs, I want something more substantial than the cedar we’ve got now. After a few years cedar gets too wobbly. Going with white oak – obviously stronger but I’m not sure I want to paint it because we have painted chairs now and would like something different. I’d like to stain the oak a reddish brown and put on a UV protected top coat. Do they make spar varnish that isn’t glossy? It looks great on boats but I don’t want that high gloss boat look for chairs and a table.
12 replies so far
View mahdee's profile
mahdee
3888 posts in 1793 days
#1 posted 07-20-2015 11:36 PM
There is an outdoor poly at Ace about $47/gallon. I have a can but have not used it yet.
-- earthartandfoods.com
View distrbd's profile
distrbd
2252 posts in 2472 days
#2 posted 07-20-2015 11:55 PM
I have not used it myself but have heard that clear penetrating epoxy sealer is an excellent finish for waterproofing outdoor furniture made with white oak.maybe you can order it in satin?
http://www.amazon.com/TotalBoat-Penetrating-Epoxy/dp/B00J36WRRG
-- Ken from Ontario, Canada
View gfadvm's profile
gfadvm
14940 posts in 2716 days
#3 posted 07-20-2015 11:59 PM
Spar Urethane comes in gloss, semi gloss, and satin BUT do not believe the claims for UV protection. It WILL crack and peel with exposure to sun for a few months. Then it will require sanding back to bare wood to refinish. BLO will not crack and peel like a clear coat and is easier to redo by just wiping more on/off.
ColonelTravis
#4 posted 07-21-2015 02:15 AM
gfadvm – interesting, I’d never thought of BLO for outdoor stuff.
gfadvm
#5 posted 07-21-2015 02:43 AM
People have been using it for trailer floors as long as I can remember.
View BurtC's profile
BurtC
103 posts in 3156 days
#6 posted 07-21-2015 03:49 AM
I just finished some cedar with Epifanes varnish. Great stuff, highly recommend.
http://www.amazon.com/gp/product/B005ADWKTG?refRID=1CTAV8PW6GCPGJ9H9TG2&ref_=pd_bia_yo_t_8
ColonelTravis
#7 posted 07-21-2015 05:37 AM
Burt that’s what I was looking at and many people recommend, how glossy is it?
View WDHLT15's profile
WDHLT15
1747 posts in 2502 days
#8 posted 07-21-2015 11:42 AM
Look at 100% pure tung oil. This link has some info.
http://www.realmilkpaint.com/products/oils/tung-oil-wood-finishes/
I suspect that an oil will be easier to maintain.
gfadvm
#9 posted 07-21-2015 01:49 PM
The Wood Whisperer had a video on Epiphanes he used on a front door in Arizona. It is pretty pricey (unless its lasts for many years).
View stefang's profile
stefang
15881 posts in 3360 days
#10 posted 07-21-2015 03:14 PM
I am convinced that a good quality marine varnish is the best. It has UV protection and is formulated to take expansion and contraction without cracking or becoming brittle. Outdoor finishes are always less effective in warm dry climates as the sun is the most destructive of the elements.
View CharleyL's profile
CharleyL
222 posts in 3390 days
#11 posted 07-21-2015 05:44 PM
An oil like BLO or Tung Oil won’t split and crack as the moisture content varies. A fresh coat can be added easily every year without much surface prep, and it stays flexible and doesn’t crack or peel with moisture changes in the wood. It was a commonly used finish for contractor’s wooden ladders years ago. White oak with a BLO top coating should be very weatherproof and easily maintained with some re-finishing every year or two.
Charley
View pjones46's profile
pjones46
1001 posts in 2669 days
#12 posted 07-21-2015 06:13 PM
The only problem with BLO is that it seems to pick up ambient dirt on the surface which becomes imbedded in the BLO over time. You must scrub prior to recoating.
If you decide to use BLO, thin the BLO down with Turps to about 3 parts turps to 1 part BLO so it really penetrates the wood and don’t forget to hit the end grain on the legs. Apply a few coats until it doesn’t absorb any more and wipe of the remaining. Make sure you let the rag you use dry out before you throw it away, spontaneous combustible..
-- Respectfully, Paul
