Converting an old desk to a workbench?
Forum topic by ppworkshop posted 07-20-2015 09:26 PM 4556 views 0 times favorited 7 replies Add to Favorites Watch
View ppworkshop's profile
ppworkshop
62 posts in 1282 days
07-20-2015 09:26 PM
Topic tags/keywords: workbench desk
I found an old desk that I want to convert into a workbench. It is 34” x 60” x 30” high. I already pulled the veneer off the top and two sides. My tentative plan is to add a laminated maple top ON TOP of the existing pine top. I thought I could let the new maple top overhang the existing top on one side, so I could put the vice on that end. I would probably add two new legs to the overhang part of the table. I also thought about adding a small sleeve/foot to the existing legs to bring it up to the height of my table saw, so it can double as an outfeed table. Has anyone done this kind of a project? What approach did you take? If not, what approach would you take if you were me? Thanks.
-- Patrick Parson Workshop
7 replies so far
ppworkshop
#1 posted 07-20-2015 09:46 PM
Forgot to post a pic of the desk. Here it is…
View rwe2156's profile
rwe2156
3235 posts in 1721 days
#2 posted 07-20-2015 09:57 PM
If the desk is, as I’m guessing, about 60” wide, it won’t be very big.
But it’ll work! You’ve already got your drawers, too.
View crank49's profile
crank49
4032 posts in 3211 days
#3 posted 07-21-2015 02:23 AM
I’ve seen old desks repurposed as work benches for several different crafts.
If it is old enough to be solid hardwood it will make a fine brnch.
A friend of mine bought 4 trailer truck loads of solid oak desks that were built in the 1940s and 1950s.
They came from a “Mental Hospital” that had been closed and the equipment and furniture liquidated.
I bought 4 of them for $25 apiece. Still have two of them. The other two were so big and heavy I just left them with the property when I sold it. They all could have been made into work benches.
Your’s looks like a good sturdy old desk.
If I was to make a workbench out of that desk I’d add another top above the existing one. Two reasons for that. 1. To get the top at a good work height. I like my bench about 34 1/2” high. Most desks are only 30” high.
2. So I could put dog holes in the work top and then not have chips and dust fall into the drawers. That stuff would fall on the bottom top.
ppworkshop
#4 posted 07-21-2015 02:43 AM
Thanks all. Crank49, thanks for the comment/info. I think I’m going to go with your approach. I am heading to the saw mill tomorrow to pick up the wood.
View DKV's profile
DKV
3940 posts in 2745 days
#5 posted 07-21-2015 03:27 AM
rwe, if you had read the op you wouldn’t have had to guess 60”.
-- This is a Troll Free zone.
View dawsonbob's profile
dawsonbob
3145 posts in 1996 days
#6 posted 07-21-2015 03:32 AM
I used to have an old solid oak desk that I used as a workbench. It weighed about eleventeen hundred pounds, and was solid as a rock. When I retired and sold that business, the desk went with it. If you have one as solid, it’ll make a great bench for you.
-- Mistakes are what pave the road to perfection
rwe2156
#7 posted 07-21-2015 10:40 AM
rwe, if you had read the op you wouldn t have had to guess 60”.
- DKV
I did read it, so that makes it even worse….......;-)
