Need help cleaning saw blades
Forum topic by vanillaman posted 07-20-2015 09:23 PM 1135 views 0 times favorited 14 replies Add to Favorites Watch
View vanillaman's profile
vanillaman
5 posts in 1298 days
07-20-2015 09:23 PM
I’m not sure if this is the right forum for this. I need to find a cleaner to remove pitch and whatever else is on my saw blades. What do you use and where do buy it. My blades have some build up on them and I need to clean them. Any help will be appreciated. Thanks in advance.
Dick
-- Dick,Maine
14 replies so far
View knotscott's profile
knotscott
8146 posts in 3575 days
#1 posted 07-20-2015 10:51 PM
I mainly use whatever household degreaser is in the closet….409, LA’s Totally Awesome, Greased Lightnin, Fantastic, Goo Gone, etc. They work great….I use the cover from a 5 gallon pail, spray on both sides, then scrub briefly with a brass brush, rinse and dry. If the pitch is stubborn, you can let it sit for a while longer before scrubbing, and/or repeat the process. Freud recommends a kerosene soak for stubborn pitch. The blade specific cleaners work well too, but are more expensive than household cleaners…..Boeshield Blade n Bit, Trend, CMT, are just a few of the brands.
View ksSlim's profile
ksSlim
1290 posts in 3090 days
#2 posted 07-20-2015 11:32 PM
Simple Green, cleaner found under the sink at my place.
Inexpensive, effective for numerous uses, even saw blades.
Lid from a five gallon bucket, add Simple Green, wait half an hour, scrub off with a kitchen scrubber.
DON’T FORGET to return the scrubber to the kitchen.
-- Sawdust and shavings are therapeutic
View TheFridge's profile
TheFridge
10718 posts in 1686 days
#3 posted 07-20-2015 11:39 PM
Oven cleaner. Dollar store variety. Let sits for an hour. Rinse off.
View distrbd's profile
distrbd
2252 posts in 2646 days
#4 posted 07-21-2015 12:05 AM
One tablespoon of Washing soda(not baking soda) in a quart of warm water,brush with a soft bristle toothbrush .
-- Ken from Ontario, Canada
View jonah's profile
jonah
1920 posts in 3498 days
#5 posted 07-21-2015 01:19 AM
I’ve used both Simple Green Pro HD (like $12 for a gallon of concentrate from the orange box) and Rockler Pitch and Resin Remover (I think $15). The Simple Green is enough cleaner to last forever, at least the way I use it. You can also reuse the Rockler stuff. I’ve reused the same bottle four times so far and it works just as well now as the first time.
I’ve heard that regular Simple Green can weaken the bond between carbide teeth and the steel blade, but I don’t remember the source or how reliable it was. That’s why I ended up with the purple stuff (the Pro HD) not the green stuff.
Either way, you soak the blade in some kind of flat-bottomed container and then brush off the crap. I use a $1 pack of copper/brass bristled brushes that I got from Harbor Freight. It gets all the gunk off. If something is stubborn, soak it longer or brush it harder.
I will say that it’s incredibly easy to cut yourself while trying to hold a blade to brush it, so wear some decent work gloves while handling them.
It’s kind of amazing how fast crap builds up on your blades when cutting soft and/or resin-y woods. I had to clean my blade twice during my workbench build from all the crap the spruce left on there.
View MrRon's profile
MrRon
5192 posts in 3443 days
#6 posted 07-21-2015 06:38 PM
- TheFridge
I have heard that oven cleaner will attack the bond between the carbide tips and the blade and could cause a tip to fly off the blade.
View dawsonbob's profile
dawsonbob
3097 posts in 1955 days
#7 posted 07-21-2015 06:46 PM
There was a previous discussion of this topic, where I first heard of CMT. Works great! Just spray it on your blade, wait awhile, and wipe it off. Leaves a protective coating on your blade. I got mine from Amazon.
-- Mistakes are what pave the road to perfection
View Ocelot's profile
Ocelot
2113 posts in 2838 days
#8 posted 07-21-2015 06:49 PM
I use the purple “simple green”. I’ve got a 5 gallon bucket that I keep the lid on. I just drop the blade in there (after threading a cable tie with a washer on it through the center hole) and leave it for a couple of days if I don’t need the blade right away. Recently, however, I left a 15-year-old Freude blade in for 3 weeks and all the writing came off the blade. So, don’t leave it over a few days.
The 5-gal bucket is a fairly snug fit for a 10” blade so if you don’t want to spend 10 minutes trying to pick the blade up out of the bottom of the bucket, think ahead and leave something through the hole so you can lift it out easily. A 12” blade will not fit.
-Paul
View Redoak49's profile
Redoak49
3663 posts in 2188 days
#9 posted 07-21-2015 06:56 PM
I hope this thread helps but this has been covered many times. The search function on this site works well and brings up many hits.
Oven cleaner will not damage the braze material or carbide under normal use. If you left it on their for weeks, who knows. I use one cleaner and it works well but it can cause skin burns so use it safely.
vanillaman
#10 posted 07-21-2015 08:10 PM
Thank you to all who responded to my request for a blade cleaner. I will try your suggestions. I have some decent blades that get gummed up with use. I tried carb & jet cleaner but it evaporates too fast and does not stay long enough to soften the crap.
Thanks much
Dick
-- Dick,Maine
View bonesbr549's profile
bonesbr549
1576 posts in 3267 days
#11 posted 07-21-2015 08:49 PM
I use Bit-n-blade. Spray it on let it sit for 30 sec scrub with a toothbrush taped to the bottle and wipe it off. Works great.
View sawdustjunkie's profile
sawdustjunkie
389 posts in 1917 days
#12 posted 07-22-2015 01:26 AM
Simple Green for me as well. It works great and I just rinse off the blade with warm water and dry.
It takes of all the gunk that collects on the blades.
-- Steve: Franklin, WI
View waho6o9's profile
waho6o9
8516 posts in 2777 days
#13 posted 07-22-2015 01:48 AM
Cool timing, I just used CMT 2050 this morning on my table saw
blade and it was very effective, highly recommend.
View mmax's profile
mmax
184 posts in 3655 days
#14 posted 07-22-2015 02:09 AM
Castrol “Super Clean”
just spray on and brush/rinse and you have a clean blade in less than a minute.
-- Always remember you're unique, just like everyone else
