| Forum topic by kdownes | posted 37 days ago | 636 views | 0 times favorited | 22 replies | ![]() |
37 days ago |
Topic tags/keywords: tung oil mahogany guitar finishing Hi everyone, I just found this site this morning, and I hope these aren’t questions that have been answered a kagillion times already. I started my very first woodworking project a couple of weeks ago, which is refinishing a solid-body electric guitar. I bought a cheap instrument made of good wood (mahogany) with a nasty original finish (camouflage!). I decided to stain it a deep red to show off the grain I imagined was underneath, then finish it off with tung oil, which I’d read was a nice and easy-to-apply finish. I took it apart, sanded away the original finish, applied a grain filler (Behlen water-based mahogany grain filler, which was pink!), sanded that down, applied Behlen red mahogany stain, sanded again, and am now in the process of applying the tung oil. I’ve cut the oil to about 50/50 with mineral spirits, which I also read was a good way to go, and have so far applied four coats. Here’s where the questions come in. - How long must I wait to reapply coats of tung oil? All the things I’ve read suggest that after applying a coat, letting it sink in, and wiping off the excess, it should be ready to recoat in 12-24 hours. But the last coat I put on was about 36 hours ago, and if I touch the surface its still a bit greasy to the touch. This has been true for previous coats as well, and I’ve gone ahead with applying more after a full 24 hours, which I hope wasn’t a big mistake. I’m doing this work in my basement, which is quite dry (we keep a dehumidifier down there set to about 60% humidity). Should I wipe it down again until the greasy-ness is gone, then apply another coat, or just wait until it is completely dry? - Related to the first questions, how long should I expect to wait after applying the final coat? I’ve seen three to four weeks elsewhere online—is this a good rule of thumb? Obviously I need this instrument to be dry and sealed since it’s going to be played regularly, and although I’m anxious to put it back together, I can be as patient as I need to be. - There seems to be some debate about using 0000 steel wool between coats. I’ve gently rubbed steel wool on the surface between the last two coats, and I imagine some of this is a matter of taste and what you want for the finished product (I’m looking for a nice matte finish, ultimately). Any recommendations on this front? I noticed that after the steel wool, the oil wiping rags pick up a lot of red tint from the stain—I’m guessing this will eventually stop happening as the oil coats build up and seal in the stain—is that correct? - I’ve seen some recommendations about using a wax on top of the final coat of tung oil—is this a good idea, particularly for something like a guitar that will be used and handled a lot? If so, any recommendations for particular waxes that would be good? I hope this isn’t too many questions for a single post. Thanks so much in advance for any advice. This is something of a test project for future, more expensive guitar refinishing projects, so I’m trying to learn as much as I can! Kieran |
37 days ago |
At this point, my question would be “How does the finish look to you?” If it pretty much looks the way you want it to look, so far….so good. Next, I think you have the wood pretty much saturated with the tung oil. It cannot absorb any more, which is why it is not drying. I’d take a clean rag and wipe it down as thoroughly as possible, then let it sit for a couple of days and see what happens. Once it dries out, I’d put a coat of paste wax on (good old Johnson’s is fine), just because I like the way it feels, and because it will add a little extra moisture protection. -- Charlie M. "Woodworking - patience = firewood" |
37 days ago |
Hello Kieran, and welcome to Lj’s. Glad you could join in. Good place to be for all your woodworkin needs, and get excellent advice and help. -- Remember--- one good turn-- gets most of the blanket!!!! |
37 days ago |
First of all, thanks for all the kind welcome emails—much appreciated! And thanks for the replies to my questions. As for how the finish looks to me at this point, it’s definitely getting there. The last coat of oil looks pretty good—more uniform with a nice sheen and color emerging. Again I’ve seen lots of descriptions online suggesting 8 to 10 coats as a good rule of thumb and so far I have only four, but maybe the wood is saturated as Charlie suggests. To Rick’s comments: this is most definitely not a vintage instrument nor a new instrument of any significant monetary value, even with the original finish. Its value, as far as I’m concerned, extends only as far as it is useful to me as both a project and an instrument to be played eventually (hopefully soon!). The whole idea was to experiment and learn, so I went in expecting that it would end up a modified instrument (and it’s going to have much better electronics in it than it came with when I’m finished). I chose tung oil after seeing lots of people using it (and seeming pleased with the results) on the Warmoth guitar forum, although of course it’s a matter of taste. As for the stain drying time, I waited nearly a full day after the second coat of stain before putting on the first coat of tung oil. |
37 days ago |
You said that the last coat of oil was not drying. Did the first three coats dry well? As Rick said, stain that wasn’t fully dry would cause the oil to be gummy, but that should have been obvious after the first coat. -- Charlie M. "Woodworking - patience = firewood" |
37 days ago |
Looking back on my notes (I’ve been trying to keep a journal of everything I’ve done for tips and things to avoid in the future), it looks like I let the stain dry for more like a few hours than a full day. It was certainly dry to the touch when I applied the first coat of oil, but maybe that wasn’t enough. Previous coats of oil seemed not gummy but a little bit greasy, though not quite as much as this last one. I’ve been following what appeared to be fairly consistent suggestions online of letting it dry for 12-24 hours and then applying another coat, so I waited at least that long between each of the previous coats. But maybe not long enough. Charlie, I took your earlier advice and wiped it down again this afternoon, and I’ll just let it hang out for a few days and look it over again to see where things stand. I still got some reddish tint on the cloth I used, which makes it seem like things aren’t getting properly sealed or the oil isn’t polymerizing. Maybe it just needs to sit for a week or so? I think I can muster the patience for that! :) Thanks again for your help. |
37 days ago |
Good plan. Some close-grained woods do not soak up stain very well. I once stained some maple and top coated it with polyurethane the next day. Well…the stain wasn’t quite dry after all, and it took about a week for the whole mess to really dry. -- Charlie M. "Woodworking - patience = firewood" |
36 days ago |
This does not really answer your question, but when I was building my one and only guitar, the true luthiers were pretty emphatic about using nitrocellulose lacquer for a finish. They claim in moves better with the instrument, sounds better, and wears well. It might still be possible to apply over the oil once it dries…check into it before hand if you decide to go that route. |
18 days ago |
I think your problem comes from a usual confusion between Tung oil and Pure Tung oil. It is very important to wipe tung oil and not to leave any wet areas – they will become a problem later. when properly cured and applied, Tung oil finish is second to none. it will be hard wearing, will look good for a long time and will resist almost anything from moisture to acids. -- The woods are lovely, dark and deep, but I have promises to keep... |
18 days ago |
Which brand of tung oil are you using? -- Randy, Rustic Artisan, a family tradition. (No PM's - auto-deleted.) - "I am a seeker, not a follower." |
18 days ago |
I’m using Woodcraft tung oil and have been cutting it with mineral spirits (I’ve since seen things online about folks using citrus-based thinners, which I think I’ll try next time). I’ve been wiping it down about 20 minutes after I apply the oil/thinner mix, and checking on in periodically during the couple of days I’ve let each coat dry to look for any emergent wet areas. After Charlie’s last post, I let it dry for a full two weeks before doing anything, then I applied another coat this past Saturday and another yesterday. I figured I’d do a couple more this way, then one final coat of 50/50 oil and thinner (or maybe no thinner?) and let it sit for about six weeks. With each coat it does seem to be getting more uniform, but even with these latest coats, some areas seem to dry much more quickly than others. Oddly, the parts that start to look less shiny right after I put a coat on are the places that feel most greasy for the longest. It is probably a combination of not-so-great surface preparation, grain filling, etc, but I’m new at this! :) Luckily the part of the body that seems to look the best and be the most uniform is the front, which is what will be seen most often, of course. The back has a mysterious splotch, and the bottom seems to be taking the longest to dry of any other part (maybe because I have it hanging up from the neck screw holes to dry?). I have a feeling that part of the problem, too, is that this guitar had a finish on it that I removed to experiment, and I may not have sanded it down far enough in some places. But from what you’ve all been saying, it’s also a matter of just being patient and letting the oil properly cure. Much as I want to put it back together and play it (which I’ll do regardless of how it looks) I am trying to cultivate that patience. I’ll post some photos soon (including some before and after shots). Thanks again to everyone for your replies and advice! |
18 days ago |
If there was a finish on it prior to this, that may be part of the problem. Also if you don’t sand it properly the oil will absorb differently on the piece causing the oil to soak in more in places causing the blotchy look. Grain filling won’t help the oil dry faster. -- Julian, Park Forest, IL |
18 days ago |
Have you considered polyurethane satin finish over the oil once it dries to give you a uniform, low lustre finish? Stan, Long Island, NY |
18 days ago |
kdownes, Sincerely, -- woodbutcher north carolina |
17 days ago |
Stan—I hadn’t considered that, but it’s a good idea. I have some Briwax I was going to put on over the oil finish once its dry, but I do like satin finishes, so maybe poly is the way to go. Any brand recommendations? Ken—I have a sinking feeling you’re right. I just went down to the basement to check on the progress, and while parts of it appear to be drying OK, even the dry parts don’t seem completely dry. I can, for example, press a finger on the surface, and it leaves a noticeable print behind—I don’t know if this is normal or not. The parts I’m concerned about don’t feel gummy so much as greasy. I didn’t use a sealer, only a grain filler. I decided to try an experiment this morning—I have a block of mahogany I got from Woodcraft that I was planning to stain the same color as the guitar and use to mount a small music box. I sanded down one side of it, applied the grain filler, and I’ll let that dry and sand it down, then stain, and try the tung oil. I’ll let that first coat sit for longer this time and see what, if anything, goes differently. If it does go differently, and I have a feeling it will… well, time to break out the sandpaper, I guess! It would be a bummer to start over but better that than a surface that will never cure properly, especially since the guitar will be rubbing up against my clothes a lot when I play it. Thanks for the tips and I’ll post again as my little experiment proceeds. |
17 days ago |
Ken, |
16 days ago |
Stan, let me make sure I’m understanding your procedure: you had a table that already had tung oil on it, and you covered that with the poly? Did you have trouble with the oil finish by itself? I guess I’m curious why you used both oil and poly—was it for the look of the oil and the protection of the poly? Folks on a guitar forum I visit have conflicting views on the look and durability of poly for guitars, but it looks like it might be a good choice. I’m learning what all these different finishes have to offer so I’d appreciate hearing more about your decision making process. Another question is: if, as Ken suggested, those first coats never dried properly and I have to start over, does that mean sanding all the way back to bare wood, and redoing the grain filler as well? I figured I’d have to restain it if I’m sanding away at those uncured coats of oil, but the grain filler has been a bit confusing to use. I have Behlen Mahogany grain filler that I used before, which is pink and stays pink under the stain in spots (not my favorite look). I’m also curious if a grain filler is necessary with either an oil or poly finish. I don’t mind having open pores as long as that doesn’t invite damage that can’t be protected against by either the oil or the poly. I chose the mahogany grain filler on the advice of someone at Woodcraft to enhance the look of the grain—why a “mahogany” colored grain filler is pink is a mystery to me. I’m also uncertain I’m doing the application correctly—I have a Behlen squeegee and wiped across the surface of the body at about a 45 degree angle to the grain, then sanded it down after it dried—is this the correct procedure? Kieran |
16 days ago |
16 days ago |
The only thing I would add to the last post is to use an oil based varnish and NOT a oil based poly. Poly is just about the hardest finish to touch up if it ever gets damaged. This is why you heard that poly isn’t a good choice for a guitar. -- Julian, Park Forest, IL |
16 days ago |
Good point, Julian. I failed to say that the Minwax Wipe On Poly only comes in oil base. It’s durable and easy to apply. |
16 days ago |
Hi Kieran, Yes… my table was finished in tung oil and the oil based Minwax Wipe On Poly worked great. It only comes in oil based. The procedure I detailed was easy and effective. Stan |
15 days ago |
raise the temp. above 75 |
10 days ago |
Hey everyone, Many thanks once again for all the advice. Ken, your detailed suggestions sound fabulous—I think I’m going to try just what you’ve recommended here on the music box stand I’m also working on (also mahogany). For the guitar, I decided to go with Stan’s advice of the wipe-on poly. Sure enough, when I started working on it again, the oil on the guitar had not cured properly in several spots and was a gummy, sticky mess when I started removing it. I sanded back to the wood, restained with full-strength stain, sanded, stained again with a diluted stain, and have since applied three coats of poly (which is drying out! Hooray!). I’ll be damned if it isn’t starting to look pretty good. Naturally, there are some flaws (one area of scratches on the front I was never able to get out) but overall it’s really starting to come together in a way that’s going to work just fine for me. I also discovered that Warmoth (a company that makes raw guitar bodies in a wide array of shapes and types of wood) uses poly on their guitars that folks buy pre-finished. While some of the folks on the guitar forum echo Julian’s comments about the difficulty of repair, it seemed like an OK way to go for this project. I’m planning to apply a bunch more coats of poly, and was wondering if I should use a wax on top of it. I did NOT use grain filler this time—I was unhappy with the look of it before and found it a real pain to work with. The open pore look and feel is just fine by me, but I wasn’t sure if that would make waxing a bad idea, of it wax on top of poly is a bad combo. I have some Briwax I got to use on my music box, which I’ve heard is good. Thanks again for all the advice—I know I promised before and after photos, which will be forthcoming once I finish putting this beast back together. Kieran |
| Forum | Topics |
Woodworking Skill Share
2892 |
3907 |
255 |
938 |
218 |
Woodworking Trade & Swap
614 |
Coffee Lounge
2359 |
LumberJocks.com Site Feedback
522 |
