buffing 'down' (not up) to semi gloss
Forum topic by jimmy J posted 07-20-2015 12:54 PM 882 views 0 times favorited 6 replies Add to Favorites Watch
View jimmy J's profile
jimmy J
229 posts in 2621 days
07-20-2015 12:54 PM
last stage of my table project. i’ve got a lot of coats of GF Enduro Var on my table, all Gloss. I want to make it closer to a semi gloss. Most of what i read suggests steel wool for satin, but i want a bit more than satin. I do have a set of Abralon pads that I was given (all the way up to p4000). Should i just use these at the grit of my choosing, or is there something to the steel wool in straight lines vs the pads on my orbital?
View conifur's profile
conifur
955 posts in 1393 days
#1 posted 07-20-2015 12:58 PM
I use 0000 steel wool with wax and comes out a semi gloss. No matter what I would try it on a sample piece before doing the table top.
View JayT's profile
JayT
6018 posts in 2453 days
#2 posted 07-20-2015 01:42 PM
Can’t you just scuff the top and add a layer of semi-gloss? The top finish coat should be the one that determines the final sheen, regardless of what is under it.
-- In theory, there is no difference between theory and practice. In practice, there is.
View Yonak's profile
Yonak
986 posts in 1763 days
#3 posted 07-20-2015 02:44 PM
last stage of my table project. i ve got a lot of coats of GF Enduro Var on my table, all Gloss. I want to make it closer to a semi gloss. Most of what i read suggests steel wool for satin, but i want a bit more than satin. I do have a set of Abralon pads that I was given (all the way up to p4000). Should i just use these at the grit of my choosing, or is there something to the steel wool in straight lines vs the pads on my orbital?
- jimmyhopps
I think you’re on the right track, jimmy. Like conifur says, rubbing the surface with a fine steel wool or pad will create a non-glossy surface, the finer the grit the higher the lustre. I always rub out the finish for furniture and items that are meant to be touched. I only leave the finish as it lays for the likes of house trim, cabinet cases, etc.
View Earlextech's profile
Earlextech
1162 posts in 2932 days
#4 posted 07-20-2015 03:02 PM
No steel wool on any water based finishes, use scotchbrite pads, can find at blue big box in various grits. Use with or without wax.
I also agree with applying the final coat in the sheen wanted but I always apply gloss as my base coats because it builds faster.
And, I would not “rub out” a set of kitchen cabinets, but a single piece, yes I would.
jimmy J
#5 posted 07-21-2015 02:10 PM
Thanks Sam.
Will try the scotchbright. do you use paste wax with scotchbright also?
Earlextech
#6 posted 07-27-2015 01:23 PM
I do. Johnson’s.
