| Forum topic by KnickKnack | posted 39 days ago | 643 views | 0 times favorited | 14 replies | ![]() |
39 days ago |
Topic tags/keywords: mortise tenon question So, I’m finally biting a bullet and trying some “proper” joints, specifically mortise and tenon. Q1: I can’t really find much information on how tight should it be?
Q2: I don’t have a lot of tools available (as in available for purchase), so I’m making the mortise with the hand-held router. This leaves me, obviously, with rounded ends. Chisels and me don’t really seem to get on, even though I keep trying, so the question is whether it’s OK (obviously it isn’t what a master craftsman would do) to simply cut the tenon a little smaller and leave the hole with the rounded ends since this shouldn’t reduce the glueing surface very much, and it’s hidden anyway. |
39 days ago |
They should fit sung but not tight for a fit you can pull out but not fall out when you hold the tenon part of the joint. If your using a router you might consider loose tenon joinery it makes for a strong joint but easier to make with a router. If you search Finewoodworking.com they have a few articles about loose tenon joinery. -- Jim from Heirloom Woodshop Southern Oregon |
39 days ago |
The tenon should fit so that you need to use a gentle push to seat it. Any tighter and it may not fit after the glue is applied and any bigger wont provide the surface contact necessary for proper gluing. It is permissible to make tenons slightly smaller, in length, than the mortise to allow for positioning. Have you considered a wood rasp or course sand paper, on a wooden block, to round over the tenon corners? |
39 days ago |
Thanks for the answers so far. |
39 days ago |
A few months ago I made (with the assistance of a few people here at LJ’s) my first raised panel cabinet. I had made a few mortise and tenon joints and discovered loose tenon. I had a new Bosch router. Making these with a router with a jig is a snap. I’ve done some regular tenons but I’ll tell you I’m sold on the ease and strength of loose tenons. And they are sort of ‘adjustable’ so you can make them fit well. -- The smell of wood, coffee in the cup, the wife let's me do my thing, the lake is peaceful. http://web.me.com/deceiver6/Deceiver/Craftsman_on_the_lake/Craftsman_on_the_lake.html |
39 days ago |
There are a number of shop made jigs that can be made for loose tenons take a look on youtube. http://www.youtube.com/watch?v=UE5VDDBh3UI -- Jim from Heirloom Woodshop Southern Oregon |
39 days ago |
Here’s a link that pretty much explain everything from an engineer’s point of view. -- Thuan |
39 days ago |
Pretty good info on these youtube links— -- rob |
26 days ago |
Thanks knick knack , i just joined recentley and you have asked everything i wanted ask about m and t joints, and you got some real good answers, thanks guys …......Gotta love lumberjocks! -- Gordon,Sydney ,Australia..Metal for money..Sawdust for love! |
18 days ago |
If you cut a lot of M&Ts May I humbly suggest investing into a Mortise machine. a bit costly at first ($150-200) but saves lots of time and is very accurate. I find it hard to do without. -- Steve |
18 days ago |
Hey KnickKnack,
#2, then three, then 1 or four, never five. -- Chips and Shavings/ see you at WWW.underconstructionlive.com |
18 days ago |
check out draw bore pins -- blaine von hagen |
18 days ago |
The tenon should fit in the mortise with a slip fit. -- Matt, Houston Texas |
18 days ago |
I have done a few M+T joints, some better than others. I always use expanding polyurethane glue. That way even the loose ones will be nice and strong when finished. -- skidiot northern illinois |
18 days ago |
M&T are great joints even though everyone thinks they are the strongest joints around there are stronger joints out there as proven in test though FWW and Home but most the time the do the job very well. something you have to keep in mind is to size them properly for the size wood and what there use in. There are tons of jigs out there any were from shop made to My Muti router and beyond what I recommend is to make a shop made jig if your up for that kind of thing and then if you don’t like it buy a factory made jigs . One doesn’t even use a router it uses a drill special bit and the jig. I’m talking about loose tenon M & t . In another test they found good old yellow glue was as strong or stronger then all glues including epoxy and polyurethane for M & T joinery. They also found that yellow glue was stronger in joints that were tight and joints that were loose than other glues. -- Jim from Heirloom Woodshop Southern Oregon |
| Forum | Topics |
Woodworking Skill Share
2897 |
3909 |
255 |
941 |
220 |
Woodworking Trade & Swap
617 |
Coffee Lounge
2363 |
LumberJocks.com Site Feedback
522 |
