Clamp question
Forum topic by Eric_S posted 44 days ago 486 views 0 times favorited 30 replies Add to Favorites Watch
View Eric_S's profile
Eric_S
98 posts in 93 days
44 days ago
So I’m still setting up shop, but should be ready to start on my nightstands within a month…hopefully. I just finished adding some extra lighting to my garage, painted the ceiling white (unfinished drywall), and added extra outlets to the walls near my workbench and tools on a couple of new circuits. I’m also getting a Grizzly g0555 bandsaw in a few weeks after hearing crappy reviews of the Delta 28-276 and great reviews of the Grizzly 14”.
Anyways, all I currently have for clamps are 8-12”, and 2-18” squeeze clamps which are only good for very small projects or glue ups. My nightstands are going to measure roughly 20×20x24 with framed sides and curved legs (still working on the sketchups and will post when finished). So its time to buy some new clamps. The only problem is I can’t afford the nice pricey Bessey/Jet parallel clamps right now since I have a Bandsaw bill and thickness planer to pay off. Are pipe clamps a good alternative? 1/2 or 3/4 inch? Any other alternatives? I’m trying to buy the most I can for the money. Any downsides to using pipe clamps versus parallel? What are good brands? Any other suggestions would be greatly appreciated. Thanks LJ’s.
Eric
17022 posts in 475 days
44 days ago
Hey Eric
I feel the best clamps for the money are pipe clamps and HF 3/4” to be specific. I usually buy 10-20 at a time.
I find that not all of the clamps I receive turn properly some just need a little vaseline on the threads and some are junk but you can return them for replacements. These clamps sell from $4.99 to $ 2.30 on sale. When you buy the brand name pipe clamps the are around $15 each so you get at least 3 times more clamps for the money. I don’t buy many tools from HF but I have always had good look with these clamps after the initial
opening and testing stage. I have other high end clamps like Bessy and others but the pipe clamps are cheap and strong and buy changing the size of the pipe you can use them for many projects .
-- Jim from Heirloom Woodshop, custom furniture maker, woodworking school, heirloomwoodshop.com
Eric_S
98 posts in 93 days
44 days ago
Thanks Jim for the suggestions. I’ve heard bad things about HF except for clamps. Is 3/4 necessary though? Does 1/2” not provide enough pressure?
I plan on buying Bessey clamps later, I just can’t afford them right now. However, Amazon is having a Cabinetmakers sale on Jet parallel which include 2-24” and 2-40” Jet parallel clamps plus 4 holders for $146.99, http://www.amazon.com/gp/product/B000F79022/ref=s9_simz_gw_s0_p60_i1?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=0VD7VR0112K24SNGPBSR&pf_rd_t=101&pf_rd_p=470938631&pf_rd_i=507846
Also, they have Bessey REVO 2-24” and 2-50” clamps for $159.99, http://www.amazon.com/gp/product/B001HSO6VI/ref=s9_simz_gw_s0_p60_t4?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=0VD7VR0112K24SNGPBSR&pf_rd_t=101&pf_rd_p=470938631&pf_rd_i=507846
Too bad that is still too much for me right now. I’ll have to remember to look at Amazon sales at a later time. I think I’ll stick with the pipe clamps for now. Thanks.
View Rustic's profile
Rustic
1253 posts in 494 days
44 days ago
Pipe clamps are always a good go to clamp. I don’t own any right now but I will soon.
-- There is no such thing as a mistake. Its called a design modification Rick Kruse, Grand Rapids, MI
44 days ago
Eric
There are lots of bad things to say about HF products and these clamps are not all perfect ,but HF is good about returns as long as you do it in a timely manner . I like 3/4” clamps because there stronger and flex less when under load but 3/4 pipe does cost a little more. If you go this route I would suggest black pipe not galvanized.
View sry's profile
sry
137 posts in 506 days
44 days ago
Agreed, pipe clamps are definitely the biggest bang for the buck, especially for longer clamps. I’ve never tried the HF models, but I have nothing but good things to say about the Rockler ones (when they’re on sale, that is, mine were $5 each a few years back)
Downsides of pipe clamps vs parallel are mostly in the jaw size (they’re very short) and the fact that the jaws don’t stay parallel (although the amount they deviate is very small). But they do have the added flexibility of resizing at will with different sized pipes. Both styles can apply large amounts of clamping pressure.
You might check out the clamp episode of the wood whisperer, or some of the overview articles (ie the free ones) at finewoodworking.com
-- Steve -- University Heights, Ohio
View sry's profile
sry
44 days ago
Expanding on what Jim said a little bit, I had read somewhere that waxing the bars of your clamps is a great way to keep them safe from glue squeezeout, which can be particularly problematic it if bridges between your work and black pipe
So I waxed the black pipe
And it was great, nothing stuck to it at all
Including the movable end of the pipe clamp fixture
Oops
Eric_S
98 posts in 93 days
44 days ago
One more question Jim. Would you go with the 3/4” ones with the base to stand on for $8.99(http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=94053) versus the regular at $6.99 (http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=31255)?
It looks like th $6.99 ones should stand as well. Too bad they don’t have sales on them right now.
TopamaxSurvivor
3063 posts in 574 days
44 days ago
Jim, Why balck pipe?
Eric_S
98 posts in 93 days
44 days ago
Thanks sry for the recommendation. Unfortunately, it doesn’t look like Rockler’s are on sale right now. Yes Jim, why Black pipe? Does that not leave marks? I’ve heard I cover the pipes in saran wrap to prevent marking.
View sry's profile
sry
44 days ago
I believe that black pipe is stronger than galvanized. I don’t remember if it’s just the surface or if the whole pipe is different, but at the very least the black pipe surface is stronger. Black is usually cheaper too
But you’re right, it can leave marks if you’re not careful
Saran wrap is a good solution. So is masking tape. Don’t wax like I did :)
44 days ago
The reason I recommend black pipe is that in time the galvanized pipe gets scared up and slips.
Eric the ones with stands are easier to use so it the price difference doesn’t bother you I would go with those.
It seems I’ve seen both for almost half that price and someone was talking about a 20% off coupon at HF
That they found on line. So If your not in a rush you might ask for a catalog and wait for a sale. Many times they have the same item on page 3(as an example) for $5.99 and on page 22 for $3.99.
44 days ago
All pipes can leave marks on your work that’s why it’s best to clamp so your pipe clamps don’t contack your wood.
View Chris Wright's profile
Chris Wright
360 posts in 379 days
44 days ago
I used pipe clamps for years before coming to the shop I’m at now where they have Bessy’s. They are great, and a real advantage to pipe clames over any type of bar clamp is that if you need a real long one, just rund down to your local hardware store or home center and pick up a coupler and an extra length of pipe and you can make them as long as you need.
-- "At its best, life is completely unpredictable." - Christopher Walken
View hairy's profile
hairy
296 posts in 430 days
44 days ago
You can cover the pipe with foam pipe insulators. They are cheap, used for insulating water pipes. You can also cut squares out of plywood or wood scraps, with a hole drilled in them you slide them on the pipe to keep your work off of the pipe. I keep a roll of wax paper handy to keep glue off of what I don’t want glue on.
-- I'm a lumberjock and I'm ok, I sleep all night and I work all day!
Eric_S
98 posts in 93 days
44 days ago
Thanks everyone for the help. I’ll keep a look out for a few weeks for the clamps jim, but I think I’ll buy the pipes now :)
44 days ago
Here’s a page that has 3/4 for $4.99
http://www.harborfreight.com/cpi/ctaf/Category.taf?CategoryID=222
View Kent Shepherd's profile
Kent Shepherd
839 posts in 184 days
44 days ago
I agree with what has been said so far. I would however, recomend you consider other type clamps as well. I use C-Clamps a lot, from tiny ones up to 8” clamps. Rockler has these on sale now http://www.rockler.com/product.cfm?page=21399&filter=clamps
Also clamps Like Irwin Quick-Grip are very handy.
You hear this over and over, but it’s so true—-You can never have too many clamps (Whatever kind you choose)
Good luck, and have fun!
44 days ago
I agree with Kent
I have many types also and the all do different jobs and as the saying goes you can never have to many clamps.
View dustbunny's profile
dustbunny
330 posts in 193 days
44 days ago
Keep an eye out at all times for clamps, like Kent said you can’t have too many.
Last year around Christmas I went to HD and in their gift ideas section they had 12” Irwin quick grip clamps in a gift set…Buy two get two. So I got four clamps for $20.00, that’s half the regular price. Love the Irwin’s.
Lisa
-- I inherited the woodworking gene and it's gone into overdrive.......
View miles125's profile (online now)
miles125
1441 posts in 903 days
44 days ago
Pony makes good bar clamps. The way you can tell a good clamp is how easy it is to use when you need 3 hands but only have two.
Eric_S
98 posts in 93 days
44 days ago
Kent, thank you for the suggestion. I actually have a bunch of Irwin quick grips which I really like (Dustbunny I got them at HD during holiday time too), but the reason I am looking for these specific kind of clams is for a few upcoming projects. The first is 2 nightstands measuring 20×20x24 inches, then a coffee table, bed frame, and then a sewing desk for my wife. All are too large for these small clamps so its time for me to get much larger ones…at a low price
Thanks Miles, I’ll remember that one ;)
Jim, I appreciate the link. The ones that don’t stand up aren’t any cheaper though….tough dillema.
View DaveR's profile
DaveR
1527 posts in 618 days
44 days ago
Don’t forget, you can also make your own clamps and they don’t have to be fancy. There are plans out there for various types from simple wedge-type clamps to cam clamps to bar clamps.
When I was building the cradle I did for my son I need some strong, lightweight clamps with a 6” throat. I didn’t need a bar nor a lot of thickness capability (the sides of the cradle are only1/8” thick). I couldn’t find anything on the market so I took a couple of hours and made a dozen to my own design with stuff I had on hand.
-- Until you spread your wings, you'll have no idea how far you can walk.
TopamaxSurvivor
44 days ago
They can be so expensive, i have always wondered why more guys don’t make them??
View wiser1934's profile
wiser1934
5 posts in 45 days
44 days ago
i endied up needing clamps. purchased bessey uniklamps from lee valley tools. best price i have seen on them.WWW.leevalley.com. check them out
-- wiser1934, new york
View firecaster's profile
firecaster
482 posts in 316 days
44 days ago
I’m constantly amazed at what I learn from you guys! This site is addicting.
-- Father of two sons. Both Eagle Scouts.
TopamaxSurvivor
44 days ago
I can’t imagine pipe clamps not standing up once you get the HF ones sorted out and the bad ones returned. How do they fail??
firecaster, you are absolutely right!! I’ve learned more about the subtlies of woodworking in a few months I’m amazed :-))
View Old's profile
Old
14 posts in 54 days
44 days ago
I have quite a few HF pipe clamps purchased years ago. Only one of them I have issues with. The little pin thing that holds the clamp to the thread rod fell off, so it’s just gets annoying sometimes when using that one clamp.
Definately get the kinds with stands if you can. I wish mine were like that.
Old
View roman's profile
roman
1125 posts in 791 days
44 days ago
hit the “auctions”
clamps are a “dime a dozen” and often “used” clamps work better then “new”ones
regardless of whether new or used
they all serve the same purpose…....they all
clamp wood together….a very simple science
Kent Shepherd
43 days ago
Old , I have fixed that problem by using a nail as a pin. Just drve it through,
bend it over and cut the excess off.
View SEE's profile
SEE
62 posts in 65 days
41 days ago
For the money, as Jim as said, you can’t beat the 3/4 HF clamps. If you’re not yet on their mailing list, sign up. Those clamps seem to go on sale about once a month. I have lots of both the 3/4 and 1/2. The 3/4 are more often used than the 1/2, for reasons mentioned above.
Ditto on the black pipe, too. Here’s a tip to save some money on the pipe: Full service hardware stores or plumbing supply houses frequently sell the pipe in 20’ lengths. You can have them cut it to your desired length and thread one end of it. That’s how I buy mine, usually for less than half the price of the pre-cut lengths available at the BORGS and many lumber/hardware stores.
Yes, the expensive parallel clamps are nice. However, at the end of the day, a clamp has one purpose in glue ups: they hold two or more pieces of wood together while the glue dries. You don’t need to spend a small fortune on clamps to get started. In fact, I have some of the HF clamps that I’ve been using for 20 years or more.
HF is known to have a lot of junk. However, there are also some well known gems in their inventory. These WW forums are a great place to get information to help you know what’s a good value for your money at HF.
-- Build for the joy of it!
