Walnut sapwood
Forum topic by wflather posted 07-19-2015 05:20 PM 1424 views 0 times favorited 6 replies Add to Favorites Watch
View wflather's profile
wflather
32 posts in 952 days
07-19-2015 05:20 PM
Topic tags/keywords: black walnut sapwood stain dye
I recently finished a plank bottom chair, using black walnut for the seat. The seat had some sapwood in it that I wanted to stain dark to more closely match the heartwood. I used Minwax black walnut stain but was rather disappointed with the results.
Before starting the next chair I am hoping for any suggestions for better ways to match the sapwood to the heartwood.
Anyone out there have experience with this?
View mahdee's profile
mahdee
3844 posts in 1674 days
#1 posted 07-19-2015 05:35 PM
Your best bet is to ask Charles Neil.
-- earthartandfoods.com
View AlaskaGuy's profile
AlaskaGuy
3912 posts in 2215 days
#2 posted 07-19-2015 06:15 PM
While you’re waiting for Charles Niel
http://www.halfinchshy.com/2010/07/equalizing-walnut-sapwood-and-heartwood.html
View DrDirt's profile
DrDirt
4421 posts in 3649 days
#3 posted 07-21-2015 06:59 PM
Ditto to alaskaguy….
Use a dye to equalize the color, then stain to get the effect you want.
I used waterbased powders made by JE Moser from woodworkers supply to do this.
http://woodworker.com/water-soluble-lt-gold-oak-aniline-dye-mssu-843-924.asp?search=dye&searchmode=2
When I am playing with finishes, and tinting, I use transtint liquid dye, and count droplets per ounce to get the right tone.
LOTS of choices for powder dye…. Lockwood is also good, used in a class, but on projects, I only used JE Moser.
Used for Walnut table
http://lumberjocks.com/projects/11726
wflather
#4 posted 07-21-2015 07:45 PM
Thanks for the feedback, I’ve used Transtint dyes on maple, love it. I found other suggestions pointing towards using SolarLux dyes diluted with the Solarlux reducer. Claims were that the color is less likely to wash out over time using this product. Then seal it with shellac and use oil based stain and poly to finish up.
http://www.woodworkerssource.com/blog/wood-conversations/3-great-ways-to-hide-sapwood-in-walnut/
DrDirt
#5 posted 07-21-2015 08:45 PM
Thanks for the feedback, I ve used Transtint dyes on maple, love it. I found other suggestions pointing towards using SolarLux dyes diluted with the Solarlux reducer. Claims were that the color is less likely to wash out over time using this product. Then seal it with shellac and use oil based stain and poly to finish up.
- wflather
Indeed the nice thing about the Solarlux is that it is ‘NGR’ Non-grain raising… whereas the waterbased dye will raise the grain. But I never had much issue with it. I would dye, let dry overnight, block sand with 320, then apply oil base stain, and finish.
wflather
#6 posted 07-21-2015 09:05 PM
Oh good, a new acronym to drop: NGR. Thanks, I actually hadn’t realized it was NGR. I am thinking that for popping curly grain raising the grain and sanding is part of the process you need to do get the best pop. For equalizing walnut sapwood/heartwood that shouldn’t be an issue.
