Delta midi lathe problem
« back to Woodturning forum
Forum topic by Belg1960 posted 07-19-2015 03:17 PM 1166 views 0 times favorited 8 replies Add to Favorites Watch
View Belg1960's profile
Belg1960
1080 posts in 3303 days
07-19-2015 03:17 PM
Topic tags/keywords: question
Guys, I screwed up my tailstock while drilling, it bound up (spun the tailstock all the way back)and now it won’t travel when I spin the handle. I’m thinking I sheared off a pin or something. Is this something that can be repaired or could it be something else? Thanks Pat
-- ***Pat*** Rookie woodworker looking for an education!!!
8 replies so far
View MrUnix's profile
MrUnix
7106 posts in 2437 days
#1 posted 07-19-2015 03:25 PM
What model? AFAIK, there is no pin on those, just a set screw on the handle. The quill can come out by advancing it all the way forward until it no longer engages the threads, so if you did it drilling (and moving it forward towards the headstock), you just need to push it back in until it engages. If you did it backing it up (away from the headstock), then you probably just need to tighten the set screw on the handle. With the model number, you can look at the parts diagram to see how it all goes together and better determine what the culprit may be.
Belg1960
#2 posted 07-19-2015 03:41 PM
Its a 46-250 type 2. Will see if I can find the manual.
View waho6o9's profile
waho6o9
8539 posts in 2815 days
#3 posted 07-19-2015 03:46 PM
waho6o9
#4 posted 07-19-2015 03:47 PM
Belg1960
#5 posted 07-19-2015 04:05 PM
Yeah found this pic as well. Took the allen key out pushed the shaft back by hand and did get it re-engaged , sort of I’m thinking one of the c rings 55 or 56 has to have something to do with re engaging it correctly. It only travels part way with help from my hand to push it back. Also there is a groove on the shaft that I would think should travel true but the shaft rotates?
waho6o9
#6 posted 07-19-2015 04:37 PM
Part 59 goes into a groove,a dado if you will, if I understand you
correctly.
View plantek's profile
plantek
312 posts in 3037 days
#7 posted 07-19-2015 04:51 PM
I have the same lathe. The shaft will rotate if the lock screw is out to far. I sounds like you may have some damaged threads or debris of some sort. Did you try complete disassemble and inspect threads Clean lithium grease then re assemble? All in all it doesn’t sound to serious.
-- If you want it and it's within reason... It's on it's way!
Belg1960
#8 posted 07-19-2015 05:50 PM
To totally dis assemble I see it as taking the the locking screw(#59) & set screw out of the handwheel, then use a hub puller to get the wheel off then the rest should slide out??
