shaper insert head(s)?
Forum topic by jar944 posted 07-19-2015 10:52 AM 734 views 0 times favorited 3 replies Add to Favorites Watch
View jar944's profile
jar944
127 posts in 1431 days
07-19-2015 10:52 AM
So I recently picked up a delta 43-375 3hp shaper. I have been looking at insert heads specifically the 40mm “euro block” type profiling heads as well as rabbiting and raised panel heads.
I have been looking @ cmt and amana for the profiling and rabbiting heads, but there seem to be a bunch of them out there so I would be interested in any brand that works well. The only panel raising head I’ve found small enough diameter for the delta seems to be the freud rp2000. The Amanda and cmt all seem to be 6-7” dia.
Can anyone recommend a general setup for home shop usage.
Additionally I’m currently looking for a power feeder, so these heads will mostly be used with one.
3 replies so far
View cabmaker's profile
cabmaker
1730 posts in 2802 days
#1 posted 07-19-2015 01:14 PM
yes there are a lot of them out there. For a really good one you will pay about half what that shaper cost you.
Any particular reason you want an insert head.
For occasional use i would go with something like grizzly lineup of carbide cutters. Good bang for the buck
jar944
#2 posted 07-19-2015 01:53 PM
- cabmaker
The multi profile insert heads just seemed like a better value. More up front cost, but cheaper adding additional profiles.
View AHuxley's profile (online now)
AHuxley
653 posts in 3315 days
#3 posted 07-19-2015 06:30 PM
CMT has a couple of multi-profile sets that are inexpensive, come in small diameters and with small bores if you that. This is the cheapest I have seen them. I personally can’t attest to how good they are.
http://www.routerbitworld.com/Cabinet-Joinery-Sets-s/1364.htm
They also have the knife sets starting at about $14 a set, CMT has a decent number of 40 and 50mm profiles.
