Biesemeyer style fences / extending rip capacity
Forum topic by ajthomas5009 posted 07-18-2015 06:18 PM 885 views 0 times favorited 3 replies Add to Favorites Watch
View ajthomas5009's profile
ajthomas5009
296 posts in 1738 days
07-18-2015 06:18 PM
Topic tags/keywords: tip question tablesaw
The cabinet saw I recently acquired came with a biesemeyer clone. Operation and adjustments are simple, my question is about possibly moving the rails and tubes to the right to increase right of the blade capacity. From the factory it’s 30” to the right and 12” to the left. The angle iron rail is 46” and the square tube is 64”.
Since it is a left tilt saw I really don’t need a fence left of the blade. So I’m hoping someone has a quick and easy answer to how far I can move everything to the right with out effecting fence operation.
-- Sometimes you're flush and sometimes you're bust, and when you're up, it's never as good as it seems, and when you're down, you never think you'll be up again, but life goes on.
3 replies so far
View Andre's profile
Andre
2019 posts in 1927 days
#1 posted 07-18-2015 06:46 PM
Not sure, depends on the Saw, My Made in the U.S.A. Delta is totally adjustable. only screws up the measuring tapes.
Just loosen the bolts on the back and put rails wherever you want them!
View alittleoff's profile
alittleoff
541 posts in 1397 days
#2 posted 07-18-2015 06:52 PM
I thought on a left tilt saw the fence should be on the right. If it’s not you should be able to move it without any problems. The tape can be replaced to match the set up.
Gerald
View MT_Stringer's profile
MT_Stringer
3173 posts in 3352 days
#3 posted 07-18-2015 08:16 PM
Here you go.
http://lumberjocks.com/projects/89734
