Planing Bowed Boards
Forum topic by MT_Stringer posted 07-18-2015 02:36 AM 2033 views 1 time favorited 13 replies Add to Favorites Watch
View MT_Stringer's profile
MT_Stringer
3168 posts in 3226 days
07-18-2015 02:36 AM
Topic tags/keywords: tip jig pine planer milling
I don’t now if this method has been posted before, but this is what I did.
I had three 2×4’s that were bowed on the wide side, not the edges. Instead of throwing them in the trash, I decided to plane ‘em flat.
I have done this before by gluing a piece of wood to each side, just as the board lay on the table. This time, I used pocket screws and attached a piece of plywood to each edge. You might be able to see the bow in the boards vs the plywood. To do this I placed the 2×4 on my workbench so the bow was up and the two end rested on the table.
Then I pre-drilled the plywood runners and screwed them to the 2×4’s.
This method worked perfect. I didn’t have to wait for the glue to dry or build some kind of planing sled.
Don’t worry about the screws hitting the planer blades. There is too much timber in between them.
After running the boards through the planer until the tops were even with the runners, I turned them over and ran them through again.
It appears I now have three boards that are about 1 1/4 inch thick…and flat! No dumpster for these guys.
Mike
Fastening the plywood runners to the 2×4.
Ready…
Done.
13 replies so far
View ChrisBarrett's profile
ChrisBarrett
99 posts in 1053 days
#1 posted 07-18-2015 12:15 PM
Yeah I have seen this method before, downside is just the screw holes.
View waho6o9's profile
waho6o9
8188 posts in 2572 days
#2 posted 07-18-2015 02:30 PM
Great idea thanks Mike!
View WoodWorkingJunkie's profile
WoodWorkingJunkie
5 posts in 1040 days
#3 posted 07-18-2015 05:59 PM
I do this on the reg, works great!
-- Please visit the WoodWorking Junkie on YOUTUBE at https://www.youtube.com/channel/UCGkDwuvbtRZZVbWYZq-cx5Q
View distrbd's profile
distrbd
2252 posts in 2442 days
#4 posted 07-18-2015 10:14 PM
Excellent idea Mike.
-- Ken from Ontario, Canada
View misterbig's profile
misterbig
45 posts in 1673 days
#5 posted 07-18-2015 10:29 PM
Doesn’t the glue in the plywood destroy the planner knives. I am sure I read that you are never to plane plywood, or mdf unless you plan on replacing blades.
I seen a method using a mdf sled and the. Place the boards on it one by one and shim(hot glue even) and once you have boards attached to sled then run the sled through until they are flat.
M
MT_Stringer
#6 posted 07-18-2015 11:08 PM
Doesn t the glue in the plywood destroy the planner knives. I am sure I read that you are never to plane plywood, or mdf unless you plan on replacing blades.
M
- misterbig
Well, if you read it on the internet, it must be true, huh? :-)
My blades are still in one piece and working just fine. Who knows, they may dull sooner than the last set. If they do, I’ll turn ‘em around and go again. It’s not like I took off a lot of material, most of which was the 2×4 sticking up.
I will say this, if I had some soft wood like white pine, I would have used it. But I didn’t have anything long enough to rip up.
misterbig
#7 posted 07-19-2015 12:24 AM
Well I was asking a question to people that may know…. not slamming the idea, just want to understand if that is acceptable approach. At a price of $65 for a set of blades don’t want to burn up $32.50 to save $6 worth of boards
M
M
- misterbig
My blades are still in one piece and working just fine. Who knows, they may dull sooner than the last set. If they do, I ll turn em around and go again. It s not like I took off a lot of material, most of which was the 2×4 sticking up.
I will say this, if I had some soft wood like white pine, I would have used it. But I didn t have anything long enough to rip up.
- MT_Stringer
View Tim's profile
Tim
3803 posts in 1957 days
#8 posted 07-19-2015 01:53 AM
Since it was a good save on those 2×4s, I really don’t mean to sound negative, but with only 1/8” bow each side, I could flatten them with a hand plane in less time than it would take to rip the plywood strips and screw them on. It’s really pretty quick to hand plane them but I suppose not everyone wants to do that or may have back/neck issues etc.
View exelectrician's profile
exelectrician
2327 posts in 2423 days
#9 posted 07-19-2015 02:26 AM
Yeah!! I remember as a noob straightening bad cuts on plywood on my jointer – Result deep grooves in my new blades where the glue was… lesson learned, the hard way.
-- Love thy neighbour as thyself
View AlaskaGuy's profile
AlaskaGuy
4127 posts in 2305 days
#10 posted 07-19-2015 06:14 AM
Yes that work but why not buy a jointer and save a ton of time and screws holes.
MT_Stringer
#11 posted 07-19-2015 03:58 PM
- AlaskaGuy
I have a jointer, but this was easier. :-)
AlaskaGuy
#12 posted 07-19-2015 05:26 PM
- AlaskaGuy
- MT_Stringer
Somehow that just doesn’t compute my mind.
Please explain how your process is easier than the tool that was specifically designed to flatten and straighten the face and edges of lumber.
MT_Stringer
#13 posted 07-19-2015 05:31 PM
- AlaskaGuy
- MT_Stringer
Somehow that just doesn t compute my mind.
- AlaskaGuy
They were bowed badly. What I did worked just fine for me and they are ready for whatever project may come along. Very easy to do. Just feed ‘em, through the planer, repeat…drink a beer. :-)
