I need a clear base plate for Bosch RA1166 plunge base for 1617EVS
Forum topic by ElChe posted 07-17-2015 02:03 PM 2946 views 0 times favorited 9 replies Add to Favorites Watch
View ElChe's profile
ElChe
630 posts in 1571 days
07-17-2015 02:03 PM
Topic tags/keywords: bosch router 1617 ra1166 base plate question
I want a clear base plate that will fit (pre-drilled) for the Bosch RA1166 plunge base that came with my Bosch 1617EVS. It would be awesome if it had the catch pin to fit porter cable style bushings (so the bushing catches on the indentation in the porter cable bushings). I have a clear plate for the fixed base but the mounting holes on the plunge base don’t match up with the pre-drilled holes on the clear base. Can’t find one. The ones I find are pre-drilled for the 1617 and 1617EVS but the mounting holes on the fixed base and the plunge base are different. Thanks. Tom
9 replies so far
View Catamount's profile
Catamount
16 posts in 2308 days
#1 posted 07-17-2015 02:49 PM
Have you tried contacting Pat Warner? He has bases for Bosch 1617 routers. Not sure if they are for the EVS but he would know or could possibly head you in the right direction.
-- VERMONT The land of the colorful fall - Just before the cold and the ice and the snow and the below zero temps
View bigJohninvegas's profile
bigJohninvegas
539 posts in 1696 days
#2 posted 07-17-2015 05:42 PM
I make my own. Really easy too. Big box store sells the clear plastic.
circle jig, or even cut it on a table saw and leave it square.
I have made a them rectangular to give an more stable hand hold. Keep the router
from Tipping while doing edge work. Really cheap too.
-- John
View rwe2156's profile
rwe2156
3230 posts in 1715 days
#3 posted 07-17-2015 11:20 PM
Yeah, why buy them?
You ought to be able to make on easily.
Use the stock base plate to locate the holes and you’re done!!
View Nubsnstubs's profile
Nubsnstubs
1433 posts in 1964 days
#4 posted 07-17-2015 11:31 PM
Yep, do above, but spec out 1/4”clear polycarbonate as the material to use. It’s literally bullet proof at 3/4” for rifle bullets. It has a slight blue/green cast to it, especially on the edge. It just doesn’t break….......... Jerry (in Tucson)
View gfadvm's profile
gfadvm
14940 posts in 2924 days
#5 posted 07-18-2015 12:23 AM
Woodcraft sells a universal clear base plate that should fit you criteria.
View ShawnSpencer's profile
ShawnSpencer
81 posts in 1776 days
#6 posted 07-18-2015 01:28 AM
I have the one from woodcraft mentioned above. Fits both fixed and plunge bases of my 1617. Works really well.
-- I know you know...
ElChe
#7 posted 07-24-2015 08:09 AM
I ordered the woodcraft plate. Thx for the suggestions. I thought about making one but I didn’t feel comfortable cutting the plastic. May try it in the future.
View BurlyBob's profile
BurlyBob
6029 posts in 2500 days
#8 posted 07-24-2015 04:19 PM
I’ve used Plexiglas to make several router bases. Just use the original base to trace the holes; cut, drill, countersink and your good to go.
bigJohninvegas
#9 posted 07-25-2015 02:08 PM
I bet that will be a good base plate. Cutting plastic with your wood tools works fine. i was given the idea, and made one in a router class that I took awhile back. I would have never thought to try it. Same as wood in many ways.
Thin plastic and thin wood act the same on your table saw. That’s the only tricky part. firm control so it doesn’t chip.
To make a round plate, I cut a square to size. Double stick tape an old plate to it, and flush trim cut it out. drill the holes while it is still taped. then drill a hole in the center just big enough for the bearing on a round over bit to fit through it. Mount it to a router base and slowly run the round over bit through it. That router class I took was amazing. Good luck, and stay safe.
-- John
