| Forum topic by NBeener | posted 44 days ago | 282 views | 0 times favorited | 8 replies | ![]() |
44 days ago |
The lid to my wife’s sewing box broke. Conveniently, it’s made of wood (!). Figured I’d try to bang one out today. Had a $0.51 piece of cull (2×6) from the Depot. The original top frame is 1/2” thick, so I surfaced the cull piece so it was good and square/smooth, did a re-saw on my TS to get about a 5/8” thick piece from which to cut my pieces. I traced the pieces onto the 5/8” board, But then … I tried to create the rabbet in the pieces so that the box’s original padded top could be flush-mounted, as before. That was a mess. One piece (one of the long ones) came out rough … but workable. I used a 1/4” kerf router bit and did it freehand (prolly’ a big mistake). When I tried the short pieces, though, I just ripped them apart. What IS the best way to do this? Is this where I’m supposed to build some sort of router jig to get the shape right?? Should I true up the four pieces, square them up properly glue them up, clamp them, and THEN try to router the rabbets in the built frame?? And … since all of my pieces look like a drunk guy did them … how WOULD YOU do this (if you dared), from the start?? I don’t have a router table (yet) or a shaper or a spindle sander or a band saw or a scroll saw or …. Trying the picture thing again…. There’s three pictures. Kindly click through to the album for a bit more info….
I quit for the day, but … will get back at it again in a day or so…. Thanks!!!! -- -- Neil |
